$ttl 38400
@ IN SOA ns1.penghosting.nl. root.ns1.penghosting.nl. (
1385376458
10800
3600
604800
38400 )
@ IN NS ns1.penghosting.nl.
@ IN NS ns2.penghosting.nl.
penghosting.nl. IN A 88.208.193.145
www.penghosting.nl. IN A 88.208.193.145
ftp.penghosting.nl. IN A 88.208.193.145
m.penghosting.nl. IN A 88.208.193.145
ns1.penghosting.nl. IN A 88.208.193.145
ns2.penghosting.nl. IN A 88.208.193.146
localhost.penghosting.nl. IN A 127.0.0.1
webmail.penghosting.nl. IN A 88.208.193.145
admin.penghosting.nl. IN A 88.208.193.145
penghosting.nl. IN MX 5 mail.penghosting.nl.
penghosting.nl. IN TXT "v=spf1 a mx a:penghosting.nl ip4:88.208.193.145 ?all"
autoconfig.penghosting.nl. IN A 88.208.193.145
restarted bind, and now I could restart apache2 as well.
No luck on starting up virtualmin, but at least I can now create manually those hosts file for all the domains and get those up and running which seems now the most important thing.
I agree Lex, you might find this a bit easier to fix if you could access Virtualmin, and just re-generate some of those files, and/or access your backups.
After starting Webmin, do you see any errors in /var/webmin/miniserv.error?
This server, is supposed to be an alias of peng.es
There is nothing in this here telling everybody that that is the case:
$ttl 38400
photosgrancanaria.com. IN SOA ns1.penghosting.nl. root.ns1.penghosting.nl. (
1385376454
10800
3600
604800
38400 )
photosgrancanaria.com. IN NS ns1.penghosting.nl.
photosgrancanaria.com. IN NS ns2.penghosting.nl.
photosgrancanaria.com. IN A 88.208.193.146
www.photosgrancanaria.com. IN A 88.208.193.146
ftp.photosgrancanaria.com. IN A 88.208.193.146
m.photosgrancanaria.com. IN A 88.208.193.146
localhost.photosgrancanaria.com. IN A 127.0.0.1
webmail.photosgrancanaria.com. IN A 88.208.193.146
admin.photosgrancanaria.com. IN A 88.208.193.146
photosgrancanaria.com. IN MX 5 mail.photosgrancanaria.com.
photosgrancanaria.com. IN TXT "v=spf1 a mx a:photosgrancanaria.com ip4:88.208.193.145 ip4:88.208.193.146 ?all"
autoconfig.photosgrancanaria.com. IN A 88.208.193.146
Alias-servers get their own BIND zone too, so it’s not incorrect that your “photosgrancanaria.com” has one. Are you seeing any problems with it? You need to be more specific in what problems you have precisely, as opposed to making post after post, telling us what stuff you do and try.
At some point, if you can’t get your machine working again, it might be easier to restore a backup. Trying to remotely fix all problems that arose due to your deleting part of /var is probably beyond the scope of this forum.
I don’t have a good backup, as I didn’t know what exactly to backup. I’ll learn that after this all working again.
By the way, I might be over-posting :), but I’m doing that so if somebody else ever has a similar problem they might find something they’re looking for.
Ok, so I’m left with this main problem:
servers that are aliases of other servers, are not showing the site they should but in stead they show the main server for that ip. If I change the main server for that ip, then that’s the site shown.
The same goes for sites, in which I created a custom username. For example, the site www.hollandsenieuwe.com shows the default website for that ip address as well, and for that site I created the custom username: hn (what normally would have been hollandsenieuwe) when I set it up.
Easiest solution might be, if it’s not too many, to delete and re-create the alias servers. Since they don’t have many settings to configure, that should go quite quickly.
Same thing happens. So the deleted stuff (early in the var partition) must have to do with it, but it became only obvious after restarting bind9, or at least, after rebooting.
Which is going to make this more complicated I guess.
In /var/bind I have now all the hosts files. Is there something near, that I’ve deleted too and that’s necessary for these aliases to work?
I really am sorry for all the help I’m asking. I’ll make sure I’ll start to learn about how to best backup this kind of stuff.
And here everything seems as it should be: the hollandsenieuwe.com.conf in /etc/apache2/sites-available looks as it should do to me, with the “hn” in stead of the “hollandsenieuwe”.
Ok, I didn’t do anything, but everything works all of a sudden. I don’t know what caused that, some dns caching going on or so? (I did restart bind and apache all the time, but hey)
Anyway, I’m not complaining.
First of all, before going to bed: THANKS A LOT everybody! It really is good to know there’s a place where I can come with my silly server problems.
I was just checking up backing up in the cloud plans, and they are really cheap, but then they have little statements that if they find out you’re a business you have to take a business plan…
