if you look at this extract from postfix you will see spamd scores on DKIM_INVALID & ,DMARC_MISSING amongst others, not that it matters much as spamd scored the email at -0.8 so wouldn’t bounce. I just thought you may be interested.
Oct 21 07:12:52 postfix/smtpd[4039869]: connect from v5243.v51e342bd.use4.send.mailgun.net[69.72.42.243]
Oct 21 07:12:53 postfix/smtpd[4039869]: 005FDA004B: client=v5243.v51e342bd.use4.send.mailgun.net[69.72.42.243]
Oct 21 07:12:53 postfix/cleanup[4040159]: 005FDA004B: message-id=<discourse/post/371274@forum.virtualmin.com>
Oct 21 07:12:54 postfix/qmgr[2157781]: 005FDA004B: from=<bounce+eadea7.01f960-bill=microsoft.com@forum.virtualmin.com>, size=59532, nrcpt=1 (queue active)
Oct 21 07:12:54 spamd[3336635]: spamd: connection from localhost [127.0.0.1]:41662 to port 783, fd 5
Oct 21 07:12:54 spamd[3336635]: spamd: setuid to bill@microsoft.com succeeded
Oct 21 07:12:54 spamd[3336635]: spamd: processing message <discourse/post/371274@forum.virtualmin.com> for bill@microsoft.com:1011
Oct 21 07:12:54 spamd[3336635]: spamd: clean message (-0.8/5.0) for bill@microfoft.com:1011 in 0.3 seconds, 58838 bytes.
Oct 21 07:12:54 spamd[3336635]: spamd: result: . 0 - DKIM_INVALID,DKIM_SIGNED,DMARC_MISSING,HELO_STATIC_HOST,HTML_IMAGE_RATIO_08,HTML_MESSAGE,MAILING_LIST_MULTI,T_SPF_HELO_TEMPERROR,T_SPF_TEMPERROR scantime=0.3,size=58838,user=bill@microsoft.com,uid=1011,required_score=5.0,
rhost=localhost,raddr=127.0.0.1,rport=41662,mid=<discourse/post/371274@forum.virtualmin.com>,autolearn=ham autolearn_force=no
Oct 21 07:12:55 postfix/local[4040473]: 005FDA004B: to=<"bill@microsoft.com"@server.microsoft.com>, orig_to=<bill@microsoft.com>, relay=local, delay=2.1, delays=1.2/0.01/0/0.89, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Oct 21 07:12:55 postfix/qmgr[2157781]: 005FDA004B: removed
