Spamd and clamd connection refused / connection denied
OS type and version AlmaLinux release 9.1
Virtualmin version 7.5
Hi all,
I’ve noticed in my maillogs the follwoing:
==> /var/log/procmail.log <==
ERROR: Could not connect to clamd on LocalSocket /run/clamd.scan/clamd.sock: Permission denied
The socket seems to be writable to world:
[root@HOST ~]# ls -lah /run/clamd.scan/clamd.sock
srw-rw-rw- 1 clamscan clamscan 0 Jan 18 18:01 /run/clamd.scan/clamd.sock
Additionally, I’ve tried to finetune spamassassin a bit, but now I get the following in the mail logs:
==> /var/log/maillog <==
Jan 27 09:45:00 HOST spamc[932651]: connect to spamd on ::1 failed, retrying (#1 of 3): Connection refused
Not sure what I did to break it.
I did enable some plugins in /etc/mail/spamassassin/*.pre but nothing I can imagine that would have a breaking effect.
spamd process is still running:
root      927446  0.0  0.6 116808 109412 ?       Ss   09:11   0:01 /usr/bin/perl -T -w /usr/bin/spamd -c -m5 -H --razor-home-dir=/var/lib/razor/ --razor-log-file=sys-syslog
but as far as I can tell, it’s not listening on any network socket:
[root@HOST ~]# netstat -tulpn | grep spamd
[root@HOST ~]#
The spamassassin config in the Virtualmin UI does not provide any sockets as far as I can tell.
I think spamd is listening on port 783:
tcp        0      0 127.0.0.1:783           0.0.0.0:*               LISTEN      933133/perl
connecting to it works:
# telnet 127.0.0.1 783
Trying 127.0.0.1...
Connected to 127.0.0.1.
Escape character is '^]'.
SPAMD/1.0 79 Timeout: (30 second socket timeout reading input from client)
Connection closed by foreign host.
I notice before I started messing with the spamassassin configurationthat the following appeared in the logs when an e-mail message was supplied to spamd:
Jan 27 06:33:20 HOST spamc[889769]: connect to spamd on ::1 failed, retrying (#1 of 3): Connection refused
Jan 27 06:33:20 HOST spamd[871045]: spamd: connection from 127.0.0.1 [127.0.0.1]:52436 to port 783, fd 5
It appears spamd is not attempting to connect anymore on ipv4, but only on ipv6?
I’ve found the logs are just not appearing in the /var/log/maillog anymore but are still available in the journalctl (journalctl -xef -u spamassassin).
I’m comparing configuration between this host and a freshly installed virtualmin, but can’t readily see what’s causing the change in log location.
