Support,
(this is a new Debian 7.1 install, using latest Virtualmin install.sh)
I got an error message:
/etc/cron.daily/spamassassin:
channel: attempt to rm channel cf file failed, attempting to continue anyway at /usr/bin/sa-update line 825.
error: can't remove file /var/lib/spamassassin/3.003002/updates_spamassassin_org/50_scores.cf: Permission denied
channel: attempt to rm channel directory failed, attempting to continue anyway at /usr/bin/sa-update line 828.
error: failed to open /var/lib/spamassassin/3.003002/updates_spamassassin_org/10_default_prefs.cf for write: Permission denied at /usr/bin/sa-update line 1118.
channel: archive extraction failed, channel failed
channel: attempt to clean up failed extraction also failed!
sa-update failed for unknown reasons
I found that there were many files owned by root in the /var/lib/spamassassin folder:
[code]# ls -laFR /var/lib/spamassassin
drwxr-xr-x 5 debian-spamd debian-spamd 4096 Aug 28 06:26 ./
drwxr-xr-x 48 root root 4096 Aug 27 22:20 …/
drwxr-xr-x 3 root root 4096 Aug 27 13:48 3.003002/
drwx------ 2 debian-spamd debian-spamd 4096 Aug 31 06:44 sa-update-keys/
drwx------ 2 debian-spamd debian-spamd 4096 Aug 28 06:26 .spamassassin/
./3.003002:
total 16
drwxr-xr-x 3 root root 4096 Aug 27 13:48 ./
drwxr-xr-x 5 debian-spamd debian-spamd 4096 Aug 28 06:26 …/
drwxr-xr-x 2 root root 4096 Aug 27 13:48 updates_spamassassin_org/
-rw-r–r-- 1 root root 2695 Aug 27 13:48 updates_spamassassin_org.cf
./3.003002/updates_spamassassin_org:
total 928
drwxr-xr-x 2 root root 4096 Aug 27 13:48 ./
drwxr-xr-x 3 root root 4096 Aug 27 13:48 …/
-rw-r–r-- 1 root root 8698 Aug 27 13:48 10_default_prefs.cf
-rw-r–r-- 1 root root 2375 Aug 27 13:48 10_hasbase.cf
-rw-r–r-- 1 root root 7607 Aug 27 13:48 20_advance_fee.cf
-rw-r–r-- 1 root root 8903 Aug 27 13:48 20_aux_tlds.cf
-rw-r–r-- 1 root root 7000 Aug 27 13:48 20_body_tests.cf
-rw-r–r-- 1 root root 1889 Aug 27 13:48 20_compensate.cf
-rw-r–r-- 1 root root 9726 Aug 27 13:48 20_dnsbl_tests.cf[/code]
I changed them by doing this:
[code]# chmod 770 /var/lib/spamassassin
chmod -R 660 /var/lib/spamassassin/*
chown -R debian-spamd:debian-spamd /var/lib/spamassassin[/code]
Thx!
