I installed Virtualmin under Debian 7 and created 3 virtual servers. I’ll use it as a mail server.
The first thing I’d like to do is create a whitelist of domains and senders for all virtual servers, as well as a blacklist of known spammers (which are local spammers and usually are not listed in RBLs).
After inspecting /etc/spamassassin/local.cf I noticed that every line within the file is commented out, so I’m gessing Virtualmin uses a custom location for Spamassassin’s configuration file.
If so, where is the configuration located?
if not, can I edit /etc/spamassassin/local.cf safely?
Thanks.
