Hi, i am new with useing Virtualmin and it is good thing. Usualy as many at start i had much problems and usualy i found all solved solutions on this forum. Now i have problem which one i didnt found here. When i click at Re-Check Configuration i got this mesage
SpamAssassin and Procmail are installed and configured for use.
The procmail command /usr/bin/procmail has 100777 permissions, when it should be setuid and setgid to root. Email may not be properly delivered or checked for spam.
What i can do to repair this and put system in ready for use by Virtualmin?
Eric
July 18, 2015, 5:49pm
2
How did you install Virtualmin, was it with the install.sh script?
Also, what distro/version are you using there?
I didnt at home last days. I install it with install.sh scrtipt and versions of softvares are
Webmin version 1.750 Virtualmin version 4.17.gpl
Eric
July 22, 2015, 10:57pm
4
And which (Linux) distribution/version is it that you’re using?
Eric
July 28, 2015, 9:05pm
6
Hmm, you mentioned both Debian and Ubuntu 14.04, but that’s close enough for now
What is the output of these commands:
dpkg -l 'procmail*'
postconf -n | grep mailbox_command
ls -l /us/bin/procmail
The output of those commands should help us get things straightened out!
root@Ubuntu-1404-trusty-64-minimal ~ # dpkg -l ‘procmail*’
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii procmail 3.22-21ubunt amd64 Versatile e-mail processor
ii procmail-wrapp 1.0-2 amd64 Suexec wrapper for procmail
root@Ubuntu-1404-trusty-64-minimal ~ # postconf -n | grep mailbox_command
mailbox_command = procmail -a “$EXTENSION”
root@Ubuntu-1404-trusty-64-minimal ~ # ls -l /us/bin/procmail
ls: cannot access /us/bin/procmail: No such file or directory
Eric
July 29, 2015, 4:18am
8
Hmm, something seems pretty unusual there.
It’s not seeing “/usr/bin/procmail” at all, and the mailbox_command line in the Postfix config is incorrect.
What is the output of this command:
cat /etc/issue
Also, could you attach your /root/virtualmin-install.log file?
I know that is something unusual.
root@Ubuntu-1404-trusty-64-minimal ~ # cat /etc/issue
Ubuntu 14.04.2 LTS \n \l
and this is log file, i cant attach them because i can attach only a pic.
http://pastebin.com/ZGkNkHwm
