First install having first removed Webmin.
Recieved the following message after install [[installs/attempts to install]] dependencies:
INFO - Something went wrong during installation: 1
A little vague. What do I do now?
Chuck
Chuck
Hey Chuck,
I suspect (and hope!) that there was a more informative error earlier in the output from the installation. I’ll admit the new logging is a bit weak (but it’s better than the no logging that prior versions did!). You can also check the virtualmin-install.log that appears in roots home directory to see if anything shows up there–this log is woefully incomplete, however…it only catches a few problems, and most still have to be found in the console output.
Checking for fully qualified hostname…
Hostname OK: fully qualified as ws012.gramtel.net
Checking for curl or wget…found /usr/bin/curl -O
Checking for perl…found /usr/bin/perl
Loading log4sh logging library…
% Total % Received % Xferd Average Speed Time Curr.
Dload Upload Total Current Left Speed
100 21395 100 21395 0 0 52310 0 0:00:00 0:00:00 0:00:00 143k
INFO - Started installation log in virtualmin-install.log
INFO - Loading OS selection library…
100 4448 100 4448 0 0 30054 0 0:00:00 0:00:00 0:00:00 98844
INFO - Succeeded.
100 2760 100 2760 0 0 23589 0 0:00:00 0:00:00 0:00:00 539k
INFO - ***********************************************************************
INFO - Operating system name: Redhat Enterprise Linux
INFO - Operating system version: 3ES
INFO - Installing virtualmin-release package for Redhat Enterprise Linux 3ES…
INFO - Disabling SELinux during installation…
./install.sh: line 1: /usr/sbin/setenforce: No such file or directory
100 10501 100 10501 0 0 53035 0 0:00:00 0:00:00 0:00:00 201k
package virtualmin-release-1.0-1.rhel is already installed
INFO - Succeeded.
INFO - Installing dependencies using command: /usr/bin/up2date --nox httpd-devel postfix bind spamassassin procmail perl perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion ruby rdoc ri mysql mysql-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_fastcgi
Hey Chuck,
Looks like the error was actually with the SELinux disabling bit…which shouldn’t be an issue that prevents successful installation (maybe). It really shouldn’t be attempting to disable it on RHEL 3, since SELinux doesn’t exist on that platform…so I’ll see about fixing that.
In the meantime, did Webmin and the virtualmin-base package get installed?
rpm -q webmin virtualmin-base
If so, then things are probably fine. If not, let me know and we can arrange for me to drop in on the box…I’ll probably need to have a look to see exactly what’s preventing that step from working.
Joe,
I am not sure why, but when I switched from a ssh session and logged in via VNC I was able to run the install script. Everything is up and seems to be running, so far. Thank you for your help.
Chuck
