I’m trying to migrate my domaines and sub-domaines from plesk 10.4.4 Update #47 to Virtualmin 3.98.gpl GPL both servers are Debian 6 based.
But the sub-domaines are not migrated.
They are supposed to be converted to sub-server.
Is there any setup to perform to allow the migartion of the sub-domaines?
Hmm, that may be a bug. I’ll talk to Jamie about that. One thing that may help is to see an example of a backup file with the behavior you’re describing. Would it be possible for Jamie to see a copy of that?
Finaly I’ve upgraded my plesk to the latest version 11 just in case
I’ve also added some output on the migration script.
/usr/share/webmin/virtual-server/migration-plesk9.pl
if ($dump->{‘admin’}->{‘domains’}) {
# Plesk 11 format
&$first_print(“Plesk 11 multi domains format …”);
I’ve never seen this output on the logs.
So it appears that the xml is not well parsed.
My apologies for the delay… I spoke with Jamie, and he did indeed say that sub-domains should be handled correctly.
Since you’re seeing problems with that – Jamie asked if you could send him a copy of your backup file.
Could you email him a copy of the most recent backup you have there, and in your email, briefly summarize the issue you’re seeing… that sub-domains aren’t being imported.
Yeah, I’d be curious what additions you have to the documentation. You can either list them here in the forums, or you can email them to me at eric@virtualmin.com.
There’s no official link to those docs yet, and Debian Wheezy hasn’t actually been released… I wasn’t expecting anyone to run into those docs quite yet
And then re-issue apt-get dist-upgrade to continue the upgrade process.
apt-get install dovecot-managesieved
I created /etc/dovecot/local.conf with this comtent:
disable_plaintext_auth = no
log_timestamp = "%Y-%m-%d %H:%M:%S "
mail_location = maildir:~/Maildir
mail_privileged_group = mail
The managesieve port now is 4190 so I added to change it in rouncube/plugins/managesieve/config.inc.php
I also added to disable apache2 php_cgi because it was activated by default.
Left to do:
proftpd doesn’t restart, rouncube /dovecot doesn’t apply managesieve rules.
