[SOLVED] Smtp timing out or I set it up wrong.
Ok. this maybe as simple as I put something wrong in this setting section on Tbird.
https://www.virtualmin.com/files/2014-06-26_195827.jpg
Ok to help with this here is my master.cf
smtp inet n - - - - smtp
#smtp inet n - - - 1 postscreen
#smtpd pass - - - - - smtpd
#dnsblog unix - - - - 0 dnsblog
#tlsproxy unix - - - - 0 tlsproxy
#submission inet n - - - - smtpd
-o syslog_name=postfix/submission
-o smtpd_tls_security_level=encrypt
-o smtpd_sasl_auth_enable=yes
-o smtpd_reject_unlisted_recipient=no
I have done the “Copy to Postfix” option in Server Configuration -> Manage SSL Certificates.
When I do netstat -an | grep :465 I get the following
tcp 0 0 0.0.0.0:465 0.0.0.0:* LISTEN
tcp6 0 0 :::465 :::* LISTEN
But this is where I am at now. A bit stuck and this is the last thing that I think is holding me back from getting on building the sites.
Darren
Adding an update,
I installed roundcube but even it will not let me send out a email to anywhere…
Anyone.
Ok, as I thought it was myself that had tweeked something wrong I did a reinstall of the os. Then the install of Virtualmin but smtp still does not work.
Neither can I get tbird to get info automatically.
If you could, I would like to get any help on this.
Darren
