[SOLVED] Postgrey not starting
due to increase in spam I thought I should play with postgrey, so I went to Virtualmin>Email messages>email greylisting and installed postgrey. It installed Postgrey 1.34 but the service did not start. When I try to start the service I get the following messages
[administrator@mail ~]$ sudo systemctl status postgrey.service -l postgrey.service - Postfix Greylisting Service Loaded: loaded (/usr/lib/systemd/system/postgrey.service; enabled) Active: failed (Result: start-limit) since Fri 2015-11-13 22:47:23 CST; 19min ago Docs: man:postgrey(8) Main PID: 16031 (code=exited, status=255) CGroup: /system.slice/postgrey.service
Nov 13 22:47:22 mail.domain.TLD systemd[1]: postgrey.service: main process exited, code=exited, status=255/n/a
Nov 13 22:47:22 mail.domain.TLD systemd[1]: Unit postgrey.service entered failed state.
Nov 13 22:47:23 mail.domain.TLD systemd[1]: postgrey.service holdoff time over, scheduling restart.
Nov 13 22:47:23 mail.domain.TLD systemd[1]: Stopping Postfix Greylisting Service…
Nov 13 22:47:23 mail.domain.TLD systemd[1]: Starting Postfix Greylisting Service…
Nov 13 22:47:23 mail.domain.TLD systemd[1]: postgrey.service start request repeated too quickly, refusing to start.
Nov 13 22:47:23 mail.domain.TLD systemd[1]: Failed to start Postfix Greylisting Service.
Nov 13 22:47:23 mail.domain.TLD systemd[1]: Unit postgrey.service entered failed state.
Any help will be greatly appreciated.
Thank you
Do you see additional errors in the email log regarding that problem? That would be located in either /var/log/maillog, or /var/log/mail.log, depending on your distribution.
Also, if you don’t see any errors in the email log, do you see any in either /var/log/messages, or /var/log/syslog?
Thank you so much for replying Eric.
I also followed the guide at: https://wiki.centos.org/HowTos/postgrey
and added
check_policy_service unix:postgrey/socket
line, but it did not help.
In the /var/log/maillog I see
Nov 15 14:37:21 mail postgrey[15098]: Process Backgrounded
Nov 15 14:37:21 mail postgrey[15098]: 2015/11/15-14:37:21 postgrey (type Net::Server::Multiplex) starting! pid(15098)
Nov 15 14:37:21 mail postgrey[15098]: Binding to UNIX socket file “/var/spool/postfix/postgrey/socket”
Nov 15 14:37:23 mail postgrey[15104]: Process Backgrounded
Nov 15 14:37:23 mail postgrey[15104]: 2015/11/15-14:37:23 postgrey (type Net::Server::Multiplex) starting! pid(15104)
Nov 15 14:37:23 mail postgrey[15104]: Binding to UNIX socket file “/var/spool/postfix/postgrey/socket”
Nov 15 14:37:24 mail postgrey[15110]: Process Backgrounded
Nov 15 14:37:24 mail postgrey[15110]: 2015/11/15-14:37:24 postgrey (type Net::Server::Multiplex) starting! pid(15110)
Nov 15 14:37:24 mail postgrey[15110]: Binding to UNIX socket file “/var/spool/postfix/postgrey/socket”
And also
Nov 15 17:11:29 mail postfix/smtpd[23464]: warning: connect to postgrey/socket: Connection refused
Nov 15 17:11:29 mail postfix/smtpd[23464]: warning: problem talking to server postgrey/socket: Connection refused
Nov 15 17:11:30 mail postfix/smtpd[23464]: warning: connect to postgrey/socket: Connection refused
Nov 15 17:11:30 mail postfix/smtpd[23464]: warning: problem talking to server postgrey/socket: Connection refused
And in /var/log/messages
Nov 15 14:37:21 mail systemd: Starting Postfix Greylisting Service... Nov 15 14:37:21 mail systemd: Started Postfix Greylisting Service. Nov 15 14:37:21 mail systemd: postgrey.service: main process exited, code=exited, status=255/n/a Nov 15 14:37:21 mail systemd: Unit postgrey.service entered failed state. Nov 15 14:37:22 mail systemd: postgrey.service holdoff time over, scheduling restart. Nov 15 14:37:22 mail systemd: Stopping Postfix Greylisting Service... Nov 15 14:37:22 mail systemd: Starting Postfix Greylisting Service... Nov 15 14:37:23 mail systemd: Started Postfix Greylisting Service. Nov 15 14:37:23 mail systemd: postgrey.service: main process exited, code=exited, status=255/n/a Nov 15 14:37:23 mail systemd: Unit postgrey.service entered failed state. Nov 15 14:37:24 mail systemd: postgrey.service holdoff time over, scheduling restart. Nov 15 14:37:24 mail systemd: Stopping Postfix Greylisting Service... Nov 15 14:37:24 mail systemd: Starting Postfix Greylisting Service... Nov 15 14:37:24 mail systemd: Started Postfix Greylisting Service. Nov 15 14:37:24 mail systemd: postgrey.service: main process exited, code=exited, status=255/n/a Nov 15 14:37:24 mail systemd: Unit postgrey.service entered failed state. Nov 15 14:37:25 mail systemd: postgrey.service holdoff time over, scheduling restart. Nov 15 14:37:25 mail systemd: Stopping Postfix Greylisting Service... Nov 15 14:37:25 mail systemd: Starting Postfix Greylisting Service... Nov 15 14:37:25 mail systemd: Started Postfix Greylisting Service. Nov 15 14:37:25 mail systemd: postgrey.service: main process exited, code=exited, status=255/n/a Nov 15 14:37:25 mail systemd: Unit postgrey.service entered failed state. Nov 15 14:37:26 mail systemd: postgrey.service holdoff time over, scheduling restart. Nov 15 14:37:26 mail systemd: Stopping Postfix Greylisting Service... Nov 15 14:37:26 mail systemd: Starting Postfix Greylisting Service... Nov 15 14:37:26 mail systemd: Started Postfix Greylisting Service. Nov 15 14:37:26 mail systemd: postgrey.service: main process exited, code=exited, status=255/n/a Nov 15 14:37:26 mail systemd: Unit postgrey.service entered failed state. Nov 15 14:37:27 mail systemd: postgrey.service holdoff time over, scheduling restart. Nov 15 14:37:27 mail systemd: Stopping Postfix Greylisting Service... Nov 15 14:37:27 mail systemd: Starting Postfix Greylisting Service... Nov 15 14:37:27 mail systemd: postgrey.service start request repeated too quickly, refusing to start. Nov 15 14:37:27 mail systemd: Failed to start Postfix Greylisting Service. Nov 15 14:37:27 mail systemd: Unit postgrey.service entered failed state. Nov 15 14:37:43 mail systemd: Reloading Postfix Mail Transport Agent.
And there is no /var/log/syslog
I am running CentOS7
Hi, so it seems like I broke the email by installing postgrey. All of the incoming emails are bouncing and not being delivered.
I sent myself a test message and this is what I see in the /var/log/maillog
Nov 16 18:15:35 mail postfix/smtpd[14007]: warning: unknown smtpd restriction: “#check_policy_service
Nov 16 18:15:35 mail postfix/smtpd[14007]: NOQUEUE: reject: RCPT from blu004-omc3s37.hotmail.com[65.55.116.112]: 451 4.3.5 Server configuration error; from=user@hotmail.com to=user@domain.tld proto=ESMTP helo=<BLU004-OMC3S37.hotmail.com>
Nov 16 18:15:35 mail postfix/local[13634]: 349A9C068E8E: to=root@mail.domain.tld, orig_to=, relay=local, delay=0.28, delays=0.07/0/0/0.22, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
any help will be greatly appreciated
I was able to fix the email issue by removing the line
check_policy_service unix:postgrey/socket,
permit
in /etc/postfix/main.cf
and then restarting postfix.
I have uninstalled postgrey, but I would still like to make it work.
Under virtulmin > Email Settings > Email Greylisting it says
Greylisting is not available on this system : The Postgrey user postgrey does not exist
However, Virtualmin can attempt to automatically install the Postgrey greylisting package for you.
Even though it was installed from vritualmin.
maybe I just need to create a user “postgrey”
is it any different than creating an email user?
Thank you
That user should be created when the postgrey package is installed.
However, just to make sure it was installed properly, you could always have it attempt reinstalling it.
Also, what is the output of this command:
rpm -qa |grep postgrey
Thank you for reply Eric,
I have tried to reinstall, uninstall then reinstall many times, but did not work.
Out put is:
[administrator@mail ~]$ rpm -qa |grep postgrey postgrey-1.34-12.el7.noarch
If I try to reinstall it from Virtualmin, I get
Installing the Postgrey package .. Installing package(s) with command /bin/yum -y install postgrey .. Loaded plugins: fastestmirror, langpacks Loading mirror speeds from cached hostfile * base: centos.les.net * epel: www.muug.mb.ca * extras: centos.les.net * updates: www.muug.mb.ca Package postgrey-1.34-12.el7.noarch already installed and latest version Nothing to do .. install complete. .. installation failed!
Holy Crap!! I finally got it working!
I uninstalled the existing postgrey by using the Yum Extender.
Then I manually downloaded the same version Postgrey-1.34-12.el7.noarch.rpm from rpm.pbone.net
There are newer version available but they require later version of perl which is not available in Centos repos I believe.
once downloaded I installed it from terminal using
sudo rpm -ivh postgrey-1.34-12.el7.noarch.rpm
and then virtualmin gave me option to enable greylisting!
I hope this information helps
I’m having the exact same problem getting Postgrey to run on Virtualmin as the original poster. I’ve followed the steps here all the way to the part about installing Postgrey from rpm.pbone.net. I’m not sure speficically how that was done. I’m assuming a repo was added, but I’m unfamiliar with how to do that. If anyone is willing to help me troubleshoot getting Postgrey to run, I would much appreciate it.
Had the exact same issue on Centos 7 (new installation of OS and Virtualmin)
I have been fighting with this all day. Tried installing manually as well as through Virtualmin. Finally after unintalling (yum erase postgrey) I went into Webmin Users and Groups and created the group postgrey and the user postgrey and then went back to Virtualmin Email Messages - email Greylisting and allowed Virtualmin to install postgrey. This time it installed properly (as far as I can tell so far) and did not display the missing user/group message.
Now I just have to see if anything else is broken with this fix.
edit:
I started having an SQL STATE[40001]: Serialization failure: 1213 Deadlock error when I had postgrey enabled. I haven’t figure out what is causing this yet. It also appear to be blocking my log files from being updated. It might be due to the postgrey User and Group I created not having the proper settings. Can someone provide me with the proper configuration for the postgrey user and group?
edit 2:
The logging issue may have been related to another problem. I commented out “$OmitLocalLogging on” in the rsyslog.conf file and logging came back. As far as I can tell postgrey appears to be working now. The service is running. I have not seen anything coming through it yet that has been rejected but it has passed several that it should have.
I’ve got the same error when tried to start postgrey on centos 7.2, the virtualmin installation didn’t create a postgrey userso the easiest way to fix this issue is to remove the postgrey package:
yum remove postgrey
and then let virtualmin reinstall the package via:
Email messages -> Email Greylisting
