(Solved) php mod_rewrite not installed/not working
I realise this has come up again and again in this forum, but I am still no closer to a solution.
I have a new minimal install of Centos7 and Virtualmin, only things added are:
wget, nano, tmpwatch, open-vm-tool
Everything else was done by the install script, everything app wise seems fine so far all in the green.
Im installing a Joomla site, have various install errors until I deleted the .htaccess file then all seems to work until I tried to browse a menu item or another internal link, I had this issue many times with Centos 7, just enabling or sometimes reinstalling the mod_rewrite module solved this.
On echecking /etc/httpd/conf.modules.d/00-base.conf, for LoadModule rewrite_module modules/mod_rewrite.so it is there!!
[root@web /]# cat /etc/httpd/conf.modules.d/00-base.conf
This file loads most of the modules included with the Apache HTTP
Server itself.
LoadModule access_compat_module modules/mod_access_compat.so
LoadModule actions_module modules/mod_actions.so
LoadModule alias_module modules/mod_alias.so
LoadModule allowmethods_module modules/mod_allowmethods.so
LoadModule auth_basic_module modules/mod_auth_basic.so
LoadModule auth_digest_module modules/mod_auth_digest.so
LoadModule authn_anon_module modules/mod_authn_anon.so
LoadModule authn_core_module modules/mod_authn_core.so
LoadModule authn_dbd_module modules/mod_authn_dbd.so
LoadModule authn_dbm_module modules/mod_authn_dbm.so
LoadModule authn_file_module modules/mod_authn_file.so
LoadModule authn_socache_module modules/mod_authn_socache.so
LoadModule authz_core_module modules/mod_authz_core.so
LoadModule authz_dbd_module modules/mod_authz_dbd.so
LoadModule authz_dbm_module modules/mod_authz_dbm.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_host_module modules/mod_authz_host.so
LoadModule authz_owner_module modules/mod_authz_owner.so
LoadModule authz_user_module modules/mod_authz_user.so
LoadModule autoindex_module modules/mod_autoindex.so
LoadModule cache_module modules/mod_cache.so
LoadModule cache_disk_module modules/mod_cache_disk.so
LoadModule data_module modules/mod_data.so
LoadModule dbd_module modules/mod_dbd.so
LoadModule deflate_module modules/mod_deflate.so
LoadModule dir_module modules/mod_dir.so
LoadModule dumpio_module modules/mod_dumpio.so
LoadModule echo_module modules/mod_echo.so
LoadModule env_module modules/mod_env.so
LoadModule expires_module modules/mod_expires.so
LoadModule ext_filter_module modules/mod_ext_filter.so
LoadModule filter_module modules/mod_filter.so
LoadModule headers_module modules/mod_headers.so
LoadModule include_module modules/mod_include.so
LoadModule info_module modules/mod_info.so
LoadModule log_config_module modules/mod_log_config.so
LoadModule logio_module modules/mod_logio.so
LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule mime_module modules/mod_mime.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule remoteip_module modules/mod_remoteip.so
LoadModule reqtimeout_module modules/mod_reqtimeout.so
LoadModule setenvif_module modules/mod_setenvif.so
LoadModule slotmem_plain_module modules/mod_slotmem_plain.so
LoadModule slotmem_shm_module modules/mod_slotmem_shm.so
LoadModule socache_dbm_module modules/mod_socache_dbm.so
LoadModule socache_memcache_module modules/mod_socache_memcache.so
LoadModule socache_shmcb_module modules/mod_socache_shmcb.so
LoadModule status_module modules/mod_status.so
LoadModule substitute_module modules/mod_substitute.so
LoadModule suexec_module modules/mod_suexec.so
LoadModule unique_id_module modules/mod_unique_id.so
LoadModule unixd_module modules/mod_unixd.so
LoadModule userdir_module modules/mod_userdir.so
LoadModule version_module modules/mod_version.so
LoadModule vhost_alias_module modules/mod_vhost_alias.so
#LoadModule buffer_module modules/mod_buffer.so
#LoadModule watchdog_module modules/mod_watchdog.so
#LoadModule heartbeat_module modules/mod_heartbeat.so
#LoadModule heartmonitor_module modules/mod_heartmonitor.so
#LoadModule usertrack_module modules/mod_usertrack.so
#LoadModule dialup_module modules/mod_dialup.so
#LoadModule charset_lite_module modules/mod_charset_lite.so
#LoadModule log_debug_module modules/mod_log_debug.so
#LoadModule ratelimit_module modules/mod_ratelimit.so
#LoadModule reflector_module modules/mod_reflector.so
#LoadModule request_module modules/mod_request.so
#LoadModule sed_module modules/mod_sed.so
#LoadModule speling_module modules/mod_speling.so
When checking by Website Options>PHP Information this model is not listed, which would backup my tests/findings.
Makes sense this is a virtual system, so how can I activate/install for all versions of PHP for all sites the mod_rewrite module.
OK this all seems to be related to the .httaccess file no surprise, the following morning my colleague worked out that commenting out FollowSymLinks in the .httaccess file resolved the issue, :frowning: so can I assume that somehow Virtualmin handles this natively?
Also See: https://www.virtualmin.com/node/24753
