ok, so… I’ve restarted postfix, i tried sending email out which works… and i can recive email from out (according to mail.log) and i can log into usermin to send email but i cant view the inbox
An error occurred listing mail in this folder : Failed to connect to localhost:143 : Connection refused
ok, so… I’ve restarted postfix, i tried sending email out which works… and i can recive email from out (according to mail.log) and i can log into usermin to send emal
Okay, that’s a good start!
Hmm, that’s an odd one, as it makes it sound as if Dovecot may not be running at the moment.
here is the dovecot.conf
no files in /etc/default/dovecot
Also i was going through forum and it seems you have helped someone with the same problem some time ago. they solved the problem by turning on IMAP. http://www.virtualmin.com/node/9758
is it a possibility that IMAP is turned off? and how do i check if its on?
Hey dont you just love it when things go well… one more happy cust. Hows everything going around here? good i hope… just getting back in the Sceen… talk at you another time…
John
