(OP notes: the mention of Sunday in the post below is a red herring, actually the failures were intermittent).
Hi All,
Every Sunday I get a problem with where my php sites a server error rather than my website.
In my virtual host apache logs I get the following:
[Sun May 10 12:13:01 2015] [warn] [client xxx.xxx.xxx.xxx (104)Connection reset by peer: mod_fcgid: error reading data from FastCGI server
[Sun May 10 12:13:01 2015] [error] [client xxx.xxx.xxx.xxx] Premature end of script headers: index.php
If I restart apache the problem goes away.
I am using Virtualmin version 4.16.gpl.
Virtualmin is running on Ubuntu precise.
Does anybody have any ideas about what is causing this and how to fix it.
If I can’t fix it directly but someone can tell me which cron is causing the issue, then I would be happy to arrange another cronjob to restart apache every Sunday too.
I had a scan through the logs from the various virtual servers that I have, and I noticed that every Sunday at 4:35 there is a weekly log rotation occurring. I guess this might be the source of the apache issue so I have scheduled a cron job to restart apache @ 5:00am on Sundays.
I have really no clue what is causing this particular issue, but I hope that change will put an end to the problem.
For anyone else who happens upon this post, try adding the following to your root crontab.
1 5 * * 6 /usr/sbin/service apache2 restart
I will follow up again if this doesn’t solve it, or if I find the route cause at some point.
I finally found the cause of the intermittent failures I was having. The Sunday timing was a red herring, actually this problem was popping up all over different virtual servers that I have at varying times. I was just noticing it more on Sundays.
It turns out I was using two apache modules headers and expires which were not part of the default installation. When I disabled these then my issues went away.
a2dismod expires
a2dismod headers
I hope that helps someone if they end up with similar issues.
