my manually created logwatch reports show these messages:
No Sys::CPU module installed. To install, execute the command:
perl -MCPAN -e ‘install Sys::CPU’
No Sys::MemInfo module installed. To install, execute the command:
perl -MCPAN -e ‘install Sys::MemInfo’
When I attempt to install Sys::CPU
I get the following message:
[root@web ~]# perl -MCPAN -e ‘install Sys::CPU’
CPAN: Storable loaded ok (v2.20)
Going to read ‘/root/.cpan/Metadata’
Database was generated on Sat, 14 Nov 2015 12:17:02 GMT
Running install for module ‘Sys::CPU’
CPAN: Data::Dumper loaded ok (v2.124)
‘YAML’ not installed, falling back to Data::Dumper and Storable to read prefs ‘/root/.cpan/prefs’
Running make for M/MZ/MZSANFORD/Sys-CPU-0.61.tar.gz
CPAN: Digest::SHA loaded ok (v5.47)
CPAN: Compress::Zlib loaded ok (v2.021)
Checksum for /root/.cpan/sources/authors/id/M/MZ/MZSANFORD/Sys-CPU-0.61.tar.gz ok
CPAN: Archive::Tar loaded ok (v1.58)
Sys-CPU-0.61/
Sys-CPU-0.61/Changes
Sys-CPU-0.61/CPU.pm
Sys-CPU-0.61/CPU.xs
Sys-CPU-0.61/Makefile.PL
Sys-CPU-0.61/MANIFEST
Sys-CPU-0.61/META.json
Sys-CPU-0.61/META.yml
Sys-CPU-0.61/README
Sys-CPU-0.61/t/
Sys-CPU-0.61/t/Sys-CPU.t
CPAN: File::Temp loaded ok (v0.22)
CPAN.pm: Going to build M/MZ/MZSANFORD/Sys-CPU-0.61.tar.gz
Checking if your kit is complete…
Looks good
Writing Makefile for Sys::CPU
Could not read ‘/root/.cpan/build/Sys-CPU-0.61-ew6qR4/META.yml’. Falling back to other methods to determine prerequisites
cp CPU.pm blib/lib/Sys/CPU.pm
/usr/bin/perl /usr/share/perl5/ExtUtils/xsubpp -typemap /usr/share/perl5/ExtUtils/typemap CPU.xs > CPU.xsc && mv CPU.xsc CPU.c
Please specify prototyping behavior for CPU.xs (see perlxs manual)
gcc -c -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -DVERSION=“0.61” -DXS_VERSION=“0.61” -fPIC “-I/usr/lib64/perl5/CORE” CPU.c
/bin/sh: gcc: command not found
make: *** [CPU.o] Error 127
/usr/bin/make – NOT OK
Warning (usually harmless): ‘YAML’ not installed, will not store persistent state
Running make test
Can’t test without successful make
Running make install
Make had returned bad status, install seems impossible
Reading here: http://customerhelp.co.za/linux/ubuntu-security/logwatch-missing-cpu-meminfo-cpan-ubuntu-14-04.html it suggests installing (for Ubuntu) libgd2-xpm-dev build-essential
I’m trying to get the equivalent for CentOs and I believe it’s this:
yum install gd-devel
yum install make gcc gcc-c++ kernel-devel
Can someone please help / confirm?
Thank you
