[SOLVED] Cloudmin not showing host creation settings
Hey guys,
So I finally bought Cloudmin Pro! YAY!!!, sorry… I’m having an issue though, I’m using Ubuntu 14.04, I’ve installed XEN hypervisor, but then after I installed Cloudmin and logged in as root, I’ve no options to create any hosts. Does anyone know what went wrong with the install or what the issue is? Thanks
-Andre
I feel I should also add that I did the Cloudmin For Physical Systems to Cloudmin 10 Upgrade.
Can anyone help? I really need to be able to restore my VMs
Although I could resolve it normally, I completely removed Cloudmin Pro and then installed Cloudmin GPL for Xen with the script downloaded from webmin.com and then I upgraded back to pro using the button in the menu. Now everything is showing up fine. Thanks anyways guys!
