Software caused connection abort
I can see that the following message occurs quite frequently (“5min interval or less”)
[warn] (103)Software caused connection abort: mod_fcgid: ap_pass_brigade failed in handle_request function
Is this something to worry about? I am not able to locate the cause or reason for this message. I just use the mod_fcgid settings create by Virtualmin.
Many thanks in advance!
The message “Software caused connection abort” typically means something like a user hitting the stop button in the browser occurred. Or perhaps a search engine’s spider left the page before it fully loaded.
However, it’s typically not harmful, unless you’re seeing errors of some sort on your site.
I can reproduce this now! Thanks!
