I am unable to send mail from my desktop client using the credintials usermin gives me, but I am able to send it through usermin… what am I missing here?
credentials are…
username: request.zapphost
credentials are…
Well, you’ll have to give us some more details than that
What’s not working exactly? What errors are you seeing on the desktop client?
On the server, what errors show up in the email log (either /var/log/mail.log or /var/log/maillog)?
It doesn’t give me any errors, it just keeps asking for password and then says authentication failed… I’ve tried tls, none, and ssl.
Does this snippet tell any stories?
Dec 13 08:44:29 ubuntu-server postfix/local[5464]: 5555D5D035: to=request.zapphost@ubuntu-server.zapphost.com, orig_to=<r$
Dec 13 08:44:29 ubuntu-server postfix/qmgr[5587]: 5555D5D035: removed
Dec 13 08:44:29 ubuntu-server spamd[5172]: prefork: child states: II
Dec 13 08:44:44 ubuntu-server dovecot: pop3-login: Login: user=<request.zapphost>, method=PLAIN, rip=192.168.1.1, lip=192.1$
Dec 13 08:44:44 ubuntu-server dovecot: POP3(request.zapphost): Disconnected: Logged out top=0/0, retr=2/13369, del=2/2, siz$
Dec 13 08:44:53 ubuntu-server dovecot: chdir(/home/absolutely-free-domain-names.com/homes/coreyman) failed with uid 1010: P$
Dec 13 08:44:53 ubuntu-server dovecot: child 5483 (pop3) returned error 89
Dec 13 08:44:53 ubuntu-server dovecot: pop3-login: Login: user=<coreyman.absolutely-free-domain-names.com>, method=PLAIN, r$
Dec 13 08:44:58 ubuntu-server dovecot: pop3-login: Login: user=<admin.x3dev.com>, method=PLAIN, rip=192.168.1.1, lip=192.16$
Dec 13 08:44:58 ubuntu-server dovecot: POP3(admin.x3dev.com): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Dec 13 08:47:43 ubuntu-server postfix/anvil[5461]: statistics: max connection rate 1/60s for (smtp:67.15.47.3) at Dec 13 08$
Dec 13 08:47:43 ubuntu-server postfix/anvil[5461]: statistics: max connection count 1 for (smtp:67.15.47.3) at Dec 13 08:44$
Dec 13 08:47:43 ubuntu-server postfix/anvil[5461]: statistics: max cache size 1 at Dec 13 08:44:23
Dec 13 08:50:37 ubuntu-server postfix/smtpd[5653]: connect from smtpgw03.myhostguy.com[216.10.240.243]
Dec 13 08:50:38 ubuntu-server postfix/smtpd[5653]: 31AFC5D035: client=smtpgw03.myhostguy.com[216.10.240.243]
Dec 13 08:50:39 ubuntu-server postfix/cleanup[5657]: 31AFC5D035: message-id=000f01ca7c03$4baaeec0$e300cc40$@com
Dec 13 08:50:49 ubuntu-server postfix/qmgr[5587]: 31AFC5D035: from=robby@it2max.com, size=1001881, nrcpt=1 (queue active)
Dec 13 08:50:49 ubuntu-server postfix/smtpd[5653]: disconnect from smtpgw03.myhostguy.com[216.10.240.243]
Dec 13 08:50:53 ubuntu-server spamc[5670]: skipped message, greater than max message size (512000 bytes)
Dec 13 08:50:53 ubuntu-server postfix/local[5658]: 31AFC5D035: to=request.zapphost@ubuntu-server.zapphost.com, orig_to=<r$
Dec 13 08:50:53 ubuntu-server postfix/qmgr[5587]: 31AFC5D035: removed
Dec 13 08:51:37 ubuntu-server dovecot: pop3-login: Login: user=<request.zapphost>, method=PLAIN, rip=192.168.1.1, lip=192.1$
Dec 13 08:51:46 ubuntu-server dovecot: POP3(request.zapphost): Disconnected: Logged out top=0/0, retr=1/1002031, del=1/1, s$
or is that all pop3 stuff
Okay, so you can log in via POP, but not via SMTP.
Are you connecting via a local LAN? Ie, is it possible your ISP is blocking port 25/SMTP?
If you’re connecting via a LAN, you should be able to authenticate without SSL or TLS using port 25 without trouble, in theory
Yea I can log in and download mail via POP…
I’m not connecting from lan, im connecting from WAN
No ports are blocked and according to whatsmyip.org port 25 is open.
I just tried connecting via 192.168.1.10 “local machine ip” and it is still refusing my login.
When you attempt to login, do you see any errors in the auth log – /var/log/auth.log?
Also, make sure saslauthd is running – you can do that with: /etc/init.d/saslauthd restart
it was running, i killed all, and restarded, and still same results
IS someone trying to brute force my SSH login??
This IP address if from china, and i don’t use that IP.
Dec 13 15:56:00 server1 sshd[14308]: Failed password for invalid user root from 60.31.211.5 port 57237 ssh2
Dec 13 15:56:01 server1 CRON[14311]: pam_unix(cron:session): session opened for user root by (uid=0)
Dec 13 15:56:03 server1 sshd[14310]: User root from 60.31.211.5 not allowed because not listed in AllowUsers
Dec 13 15:56:03 server1 sshd[14310]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=60.31.211.5 user=root
Dec 13 15:56:05 server1 sshd[14310]: Failed password for invalid user root from 60.31.211.5 port 57601 ssh2
Dec 13 15:56:08 server1 sshd[14327]: User root from 60.31.211.5 not allowed because not listed in AllowUsers
Dec 13 15:56:08 server1 sshd[14327]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=60.31.211.5 user=root
Dec 13 15:56:10 server1 sshd[14327]: Failed password for invalid user root from 60.31.211.5 port 57995 ssh2
Dec 13 15:56:13 server1 sshd[14330]: User root from 60.31.211.5 not allowed because not listed in AllowUsers
Dec 13 15:56:13 server1 sshd[14330]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=60.31.211.5 user=root
I’d be surprised if you weren’t seeing constant breakin attempts
There’s boatloads of worms and malcontents on the Internet constantly in search of easy targets.
The thing to do is keep your software up to date (both OS software as well as web apps), keep your passwords secure, and disable services you don’t need.
I don’t notice any login failures for request.zapphost in that log… Is that the right place to be looking for SMTP login failures?
Now I found another attempt from someone in Honduras
I’m going to #ubuntu right now to try and make my ssh more secure.
Maybe even lock out after so many login attempts.
you can run sshd on a different port to stop the automated scripts, since they search for port 22 usually
Yeah, in either /var/log/mail.log, or /var/log/auth.log, you should see something that suggests that your client is connecting… be it a failed login, an error of some kind, or at least a notice that your particular IP has connected to the server.
If you don’t see that much, it’s likely your desktop isn’t hitting port 25 on the server for some reason.
This is me trying to log in from work.
Dec 15 08:33:03 server1 postfix/smtpd[29650]: warning: SASL authentication failure: cannot connect to saslauthd server: Permission denied
Dec 15 08:33:03 server1 postfix/smtpd[29650]: warning: 66-76-106-250.tylrtx.sta.suddenlink.net[66.76.106.250]: SASL LOGIN authentication failed: $
Dec 15 08:33:05 server1 postfix/smtpd[29650]: warning: SASL authentication failure: cannot connect to saslauthd server: Permission denied
Dec 15 08:33:05 server1 postfix/smtpd[29650]: warning: SASL authentication failure: Password verification failed
Dec 15 08:33:05 server1 postfix/smtpd[29650]: warning: 66-76-106-250.tylrtx.sta.suddenlink.net[66.76.106.250]: SASL PLAIN authentication failed: $
Dec 15 08:33:05 server1 postfix/smtpd[29650]: warning: 66-76-106-250.tylrtx.sta.suddenlink.net[66.76.106.250]: SASL LOGIN authentication failed: $
Dec 15 08:33:07 server1 postfix/smtpd[29650]: warning: SASL authentication failure: cannot connect to saslauthd server: Permission denied
Dec 15 08:33:07 server1 postfix/smtpd[29650]: warning: SASL authentication failure: Password verification failed
Dec 15 08:33:07 server1 postfix/smtpd[29650]: warning: 66-76-106-250.tylrtx.sta.suddenlink.net[66.76.106.250]: SASL PLAIN authentication failed: $
Dec 15 08:33:10 server1 postfix/smtpd[29650]: warning: SASL authentication failure: cannot connect to saslauthd server: Permission denied
Dec 15 08:33:10 server1 postfix/smtpd[29650]: warning: 66-76-106-250.tylrtx.sta.suddenlink.net[66.76.106.250]: SASL LOGIN authentication failed: $
Dec 15 08:33:17 server1 postfix/smtpd[29650]: disconnect from 66-76-106-250.tylrtx.sta.suddenlink.net[66.76.106.250]
it keeps saying password failure and I know my password is correct.
Ahh, those logs are a bit more forthcoming about what the issue is… it looks like you’re seeing an saslauthd permissions issue.
Try running this:
usermod -a -G sasl postfix
Followed by restarting Saslauthd:
And see if that does the trick for you.
that did the trick, what are those commands?
it added a user id and a group to postfix?
