Thank you for all your help Joe. I’ll look into it.
O.K. usr/sbin/postconf, I can’t edit and master.cf has these parameters:
# -o syslog_name=postfix/submission
# -o smtpd_tls_security_level=encrypt
# -o smtpd_sasl_auth_enable=yes
# -o smtpd_reject_unlisted_recipient=no
# -o smtpd_client_restrictions=$mua_client_restrictions
# -o smtpd_helo_restrictions=$mua_helo_restrictions
# -o smtpd_sender_restrictions=$mua_sender_restrictions
# -o smtpd_recipient_restrictions=permit_sasl_authenticated,reject
# -o milter_macro_daemon_name=ORIGINATING
No spaces
Is that literally the entire config file? Because that’s nonsensical. It literally does nothing (that’s nothing but comments).
A default master.cf looks something like this:
# Postfix master process configuration file. For details on the format
# of the file, see the master(5) manual page (command: "man 5 master" or
# on-line: http://www.postfix.org/master.5.html).
# Do not forget to execute "postfix reload" after editing this file.
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (no) (never) (100)
smtp inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may
#smtp inet n - n - 1 postscreen
#smtpd pass - - n - - smtpd
#dnsblog unix - - n - 0 dnsblog
#tlsproxy unix - - n - 0 tlsproxy
#submission inet n - n - - smtpd
# -o smtpd_tls_auth_only=yes
# -o smtpd_relay_restrictions=permit_sasl_authenticated,reject
#smtps inet n - n - - smtpd
# -o syslog_name=postfix/smtps
# -o smtpd_tls_wrappermode=yes
#628 inet n - n - - qmqpd
pickup unix n - n 60 1 pickup
cleanup unix n - n - 0 cleanup
qmgr unix n - n 300 1 qmgr
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - n 1000? 1 tlsmgr
rewrite unix - - n - - trivial-rewrite
bounce unix - - n - 0 bounce
defer unix - - n - 0 bounce
trace unix - - n - 0 bounce
verify unix - - n - 1 verify
flush unix n - n 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - n - - smtp
relay unix - - n - - smtp
-o syslog_name=postfix/$service_name
# -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - n - - showq
error unix - - n - - error
retry unix - - n - - error
discard unix - - n - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - n - - lmtp
anvil unix - - n - 1 anvil
scache unix - - n - 1 scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent. See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
#maildrop unix - n n - - pipe
# flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
# lmtp cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
# mailbox_transport = lmtp:inet:localhost
# virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
# user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
# flags=R user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
#uucp unix - n n - - pipe
# flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
#ifmail unix - n n - - pipe
# flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
#bsmtp unix - n n - - pipe
# flags=Fq. user=bsmtp argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient
#scalemail-backend unix - n n - 2 pipe
# flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store
# ${nexthop} ${user} ${extension}
#mailman unix - n n - - pipe
# flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
submission inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may
smtps inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may -o smtpd_tls_wrappermode=yes
postlog unix-dgram n - n - 1 postlogd
Note this is probably not actually default, as it’s from one of my production servers and may have customizations, I don’t know.
# of the file, see the master(5) manual page (command: "man 5 master").
# (yes) (yes) (yes) (never) (100)
smtps inet n - n - - smtpd -o syslog_name=postfix/smtps -o smtpd_tls_wrappermode=yes -o smtpd_sasl_auth_enable=yes -o smtpd_reject_unlisted_recipient=no -o smtpd_client_restrictions=$mua_client_restrictions -o smtpd_helo_restrictions=$mua_helo_restrictions -o smtpd_sender_restrictions=$mua_sender_restrictions -o smtpd_recipient_restrictions=permit_sasl_authenticated,reject -o milter_macro_daemon_name=ORIGINATING
Job for dovecot.service failed because the control process exited with error cod e. See "systemctl status dovecot.service" and "journalctl -xe" for details.
[root@ns10 ~]# systemcontl status dovecot.service
-bash: systemcontl: command not found
[root@ns10 ~]# systemctl status dovecot.service
● dovecot.service - Dovecot IMAP/POP3 email server
Loaded: loaded (/usr/lib/systemd/system/dovecot.service; enabled; vendor pres et: disabled)
Active: failed (Result: exit-code) since Wed 2021-06-23 00:28:46 UTC; 1min 58 s ago
Docs: man:dovecot(1)
http://wiki2.dovecot.org/
Process: 375 ExecStart=/usr/sbin/dovecot (code=exited, status=89)
Process: 373 ExecStartPre=/usr/sbin/portrelease dovecot (code=exited, status=0 /SUCCESS)
Process: 371 ExecStartPre=/usr/libexec/dovecot/prestartscript (code=exited, st atus=0/SUCCESS)
Main PID: 31651 (code=exited, status=0/SUCCESS)
Jun 23 00:28:46 ns10.intrelligentsystems.com systemd[1]: Starting Dovecot IMA...
Jun 23 00:28:46 ns10.intrelligentsystems.com dovecot[375]: Fatal: Dovecot is ...
Jun 23 00:28:46 ns10.intrelligentsystems.com dovecot[375]: master: Fatal: Dov...
Jun 23 00:28:46 ns10.intrelligentsystems.com systemd[1]: dovecot.service: con...
Jun 23 00:28:46 ns10.intrelligentsystems.com systemd[1]: Failed to start Dove...
Jun 23 00:28:46 ns10.intrelligentsystems.com systemd[1]: Unit dovecot.service...
Jun 23 00:28:46 ns10.intrelligentsystems.com systemd[1]: dovecot.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
Please start another topic for Dovecot problems. Dovecot and Postfix are not related (except in that they both deal with mail…but Dovecot cannot be involved in a failure to send mail).
TY Joe. I think I pinpointed it to this:
Failed to open /etc/ssl/private/dovecot.pem for writing : No such file or directory
Dovecot fails to start because of it. Postfix is sending email normally, but now not receiving because of Dovecot.
Hi
Please go to /etc/postfix and check if you have git revisions there:
git diff --stat HEAD~
5
HEAD
This should give you 5 last changes on the Postfix files. Last time I had similar situation and had to restore config files from git. They were wipe out after some update
Thank you. I actually created the folder manually and requested another cert. It worked. My issue now is that, no matter how I configure Postfix, I can’t get it to receive mail from the outside and the local mail is stuck in queue. What a mission this has been…
