SMTP authentication failure after configuring SSL certficate
Hi, everyone
After successfully configuring Dovecot with valid Let’s Encrypt certificates (manually), I have also configured Postfix to use them.
But, after specifying the certificates, saving and restarting Postfix, the authentication failures continue. I have also redefined the passwords in Virtualmin -> Edit Users, but only IMAP works (SMTP doesn’t).
Here are the logs when trying to connect with Thunderbird:
Sep 25 13:30:42 ns1 postfix/smtpd[653]: connect from unknown[187.180.182.192] Sep 25 13:30:43 ns1 postfix/smtpd[653]: warning: SASL authentication failure: Password verification failed Sep 25 13:30:43 ns1 postfix/smtpd[653]: warning: unknown[187.180.182.192]: SASL PLAIN authentication failed: authentication failure Sep 25 13:30:43 ns1 postfix/smtpd[653]: warning: unknown[187.180.182.192]: SASL LOGIN authentication failed: authentication failure Sep 25 13:31:01 ns1 postfix/smtpd[653]: warning: SASL authentication failure: Password verification failed Sep 25 13:31:01 ns1 postfix/smtpd[653]: warning: unknown[187.180.182.192]: SASL PLAIN authentication failed: authentication failure Sep 25 13:31:02 ns1 postfix/smtpd[653]: warning: unknown[187.180.182.192]: SASL LOGIN authentication failed: authentication failure Sep 25 13:31:04 ns1 postfix/smtpd[653]: disconnect from unknown[187.180.182.192] ehlo=2 starttls=1 auth=0/4 quit=1 commands=4/8
And here are the logs when trying to connect with Gmail:
Sep 25 13:31:25 ns1 postfix/smtpd[653]: connect from mail-wm0-f49.google.com[74.125.82.49] Sep 25 13:31:25 ns1 postfix/smtpd[653]: warning: SASL authentication failure: Password verification failed Sep 25 13:31:25 ns1 postfix/smtpd[653]: warning: mail-wm0-f49.google.com[74.125.82.49]: SASL PLAIN authentication failed: authentication failure Sep 25 13:31:25 ns1 postfix/smtpd[653]: lost connection after AUTH from mail-wm0-f49.google.com[74.125.82.49] Sep 25 13:31:25 ns1 postfix/smtpd[653]: disconnect from mail-wm0-f49.google.com[74.125.82.49] ehlo=2 starttls=1 auth=0/1 commands=3/4
Here is the output of postconf -n:
alias_database = hash:/etc/aliases alias_maps = hash:/etc/aliases allow_percent_hack = no append_dot_mydomain = no biff = no broken_sasl_auth_clients = yes home_mailbox = Maildir/ inet_interfaces = all inet_protocols = all mailbox_command = /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME mailbox_size_limit = 0 message_size_limit = 102400000 milter_default_action = accept milter_protocol = 2 mydestination = $myhostname, localdomain, localhost, localhost.localdomain, localhost, ns1.adimira.com myhostname = ns1.adimira.com mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128 non_smtpd_milters = inet:localhost:8891 readme_directory = no recipient_delimiter = + sender_bcc_maps = hash:/etc/postfix/bcc smtp_tls_security_level = may smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu) smtpd_milters = inet:localhost:8891 smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination, reject_unknown_recipient_domain, reject_rbl_client sbl.spamhaus.org, reject_rbl_client bl.spamcop.net, reject_rbl_client zen.spamhaus.org, reject_rbl_client cbl.abuseat.org, reject_rbl_client b.barracudacentral.org, permit smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination smtpd_sasl_auth_enable = yes smtpd_tls_CAfile = /etc/letsencrypt/live/adimira.com/fullchain.pem smtpd_tls_cert_file = /etc/letsencrypt/live/adimira.com/cert.pem smtpd_tls_key_file = /etc/letsencrypt/live/adimira.com/privkey.pem smtpd_tls_security_level = encrypt smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache smtpd_use_tls = yes virtual_alias_maps = hash:/etc/postfix/virtual
I believe this is also being discussed in this thread: https://www.virtualmin.com/node/53714
Summary answer: --minimal install doesn’t include SASL, and a number of other elements of the mail stack. If you want to host mail locally, you probably don’t want the minimal installation target.
