I have recently set up a 1&1 new server with Webim/Virtualmin and everything seems to be running smoothly except for outgoing connections.
On our original 1&1 server the outgoing connections whether using wget from the command line or file_get_contents from php are pretty much instant regardless of whether it’s a local domain on the server or an external domain like google.com (typically less than a second)
On our new server these same outgoing connections are taking 5 seconds. And it always seems to be 5 seconds as if it’s limited. I have been unable to find a reason for this.
Not even sure if this is Virtualmin realted at all, but any help would be much appreciated, as this is causing scripts on the server to timeout.
CentOS release 6.5 (Final)
Webmin version 1.680
Virtualmin version 4.06.gpl GPL
Comparing the servers, it takes 1-2 seconds on the new server , but on the old server after the 1st time it’s instant. On the new server it takes the same time no matter how may times.
