Slow FTP Connection
Hi all,
The problem is that FTP connections are very slow although the SFTP ones are very fast!
I want to lock users to their home folders. If they use SFTP they can easily browse the whole server and I don’t want it. On the other hand, they can see only their own files via ftp, but very slowly (e.g. it takes 5-10 seconds to see the contents of a folder).
What can be the problem? What do you suggest?
Any help will be appreciated…
Ismet
OK! I have just found the solution!
In the Webmin > Servers > ProFTPd Server > Networking Tools,
I change the value of "Do reverse DNS lookups of client addresses?" to "NO". Then, the ftp worked like a charm!
I’m glad you figured it out!
While that should improve performance, it surprised me that it’d do so as dramatically as it did for you.
I’d double-check that DNS is working properly on your server, perhaps by logging in over SSH and just running “dig” to make sure you get some output.
Also, regarding SCP/SFTP – you might want to look into the "scponly" shell:
http://www.sublimation.org/scponly/wiki/index.php/Features
You can use it to prevent SSH access while allowing secure file transfers – as well as chroot’ing users to their home directory.
Have a good one!
