Howdy all,
I have some difficulties using Postfix SMTP when I try to send mail using a different user account than the "Server Owner" or "main" server account. I am sure it is only some minor issue with my Postfix config or something, but who knows!?
Here is what my mail.log shows:
[code:1]Aug 16 15:28:27 mydomain postfix/smtpd[17828]: warning: 83.228.3.226: hostname 226-3-228-83.btc-net.bg verification failed: No address associated with nodename
Aug 16 15:28:27 mydomain postfix/smtpd[17828]: connect from unknown[83.228.3.226]
Aug 16 15:28:30 mydomain postfix/smtpd[17828]: warning: SASL authentication failure: Could not open db
Aug 16 15:28:30 mydomain postfix/smtpd[17828]: warning: SASL authentication failure: no secret in database
Aug 16 15:28:30 mydomain postfix/smtpd[17828]: warning: unknown[83.228.3.226]: SASL CRAM-MD5 authentication failed: authentication failure
Aug 16 15:28:30 mydomain postfix/smtpd[17828]: warning: SASL authentication failure: Password verification failed
Aug 16 15:28:30 mydomain postfix/smtpd[17828]: warning: unknown[83.228.3.226]: SASL PLAIN authentication failed: authentication failure
Aug 16 15:28:30 mydomain postfix/smtpd[17828]: warning: unknown[83.228.3.226]: SASL LOGIN authentication failed: authentication failure
Aug 16 15:28:43 mydomain postfix/smtpd[17828]: lost connection after AUTH from unknown[83.228.3.226][/code:1]
That happens if I try to send mail using the "second" user account.
Using the "main" account at least I can login and send. The logs also look a bit different then before:
[code:1]Aug 16 15:40:18 mydomain postfix/smtpd[18185]: warning: 83.228.3.226: hostname 226-3-228-83.btc-net.bg verification failed: No address associated with nodename
Aug 16 15:40:18 mydomain postfix/smtpd[18185]: connect from unknown[83.228.3.226]
Aug 16 15:40:19 mydomain postfix/smtpd[18185]: warning: SASL authentication failure: Could not open db
Aug 16 15:40:19 mydomain postfix/smtpd[18185]: warning: SASL authentication failure: no secret in database
Aug 16 15:40:19 mydomain postfix/smtpd[18185]: warning: unknown[83.228.3.226]: SASL CRAM-MD5 authentication failed: authentication failure
Aug 16 15:40:19 mydomain postfix/smtpd[18185]: 0AD371B1099: client=unknown[83.228.3.226], sasl_method=PLAIN, sasl_username=mydomain
Aug 16 15:40:19 mydomain postfix/cleanup[18188]: 0AD371B1099: message-id=<46C445B7.2030900@mydomain.net>
Aug 16 15:40:19 mydomain postfix/qmgr[18103]: 0AD371B1099: from=<webmaster@mydomain.net>, size=2540, nrcpt=1 (queue active)
Aug 16 15:40:19 mydomain postfix/smtpd[18185]: disconnect from unknown[83.228.3.226]
Aug 16 15:40:19 mydomain postfix/local[18189]: 0AD371B1099: to=<owner@mail.mydomain.net>, orig_to=<webmaster@mydomain2.com>, relay=local, delay=0.05, delays=0.02/0.01/0/0.02, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Aug 16 15:40:19 mydomain postfix/qmgr[18103]: 0AD371B1099: removed[/code:1]
Looks like SASL is first acting up, but then agrees to "sasl_method=PLAIN" & "sasl_username=mydomain". weird…!
Is this related to SASL or Postfix? I have no clue where I should start looking?! I tried to chroot smtp but no success, same errors.
My main.cf:
[code:1]broken_sasl_auth_clients = yes
command_directory = /opt/local/sbin
config_directory = /opt/local/etc/postfix
daemon_directory = /opt/local/libexec/postfix
debug_peer_level = 2
home_mailbox = Maildir/
html_directory = no
mailbox_size_limit = 0
mailq_path = /opt/local/bin/mailq
manpage_directory = /opt/local/share/man
mydestination = localhost.$mydomain, localhost, $mydomain, $myhostname, 192.168.2.0/24, 83.228.3.226
mydomain = mail.mydomain.net
myhostname = mail.mydomain.net
mynetworks = localhost.$mydomain, localhost, $mydomain, $myhostname, 192.168.2.0/24, 83.228.3.226
mynetworks_style = host
newaliases_path = /opt/local/bin/newaliases
readme_directory = /opt/local/share/postfix
sample_directory = /opt/local/share/postfix/sample
sendmail_path = /opt/local/sbin/sendmail
setgid_group = postdrop
smtpd_recipient_restrictions = permit_mynetworks,permit_sasl_authenticated,reject_unauth_destination
smtpd_sasl_auth_enable = yes
smtpd_sasl_authenticated_header = yes
unknown_local_recipient_reject_code = 550
[/code:1]
smtpd.conf:
[code:1]pwcheck_method: saslauthd
mech_list: PLAIN LOGIN CRAM-MD5 DIGEST-MD5[/code:1]
Thanks in advance…
Tony
ps: "mydomain" in the logs and config is NOT my real hostname of course
EDIT: Allow me one more question regarding this problem… Where does SASL actually get the passwords from?? Would I not need something like this in my main.cf: smtp_sasl_password_maps = hash:/etc/postfix/saslpass<br><br>Post edited by: tony.p, at: 2007/08/16 17:46
