Site with letsencrypt cert present unformated
πŸ›ˆ SYSTEM INFORMATION
OS type and version Ubuntu/20.04
Webmin version 1.984
Virtualmin version 6.17-3 Pro
Related packages letsencrypt
When I obtain the cert and goto https://geekscove.com
the site present unformated pretty much everything is vertical, I have the lock on browser
found this in a log
[Sun Jan 30 17:06:40.260027 2022] [ssl:warn] [pid 943:tid 140567063227456] AH01909: geekscove.com:443:0 server certificate does NOT include an ID which matches the server name
Keith
@kdmiller45 - its simple fix your html and php code or whatever code you are using… its obvious. - If you cannot do that hire web developer who can do this :wink:
Let the client know what issue is…
Not relevant anymore; the lock symbol is showing in the browser so your SSL certificate has been deployed successfully.
I had a quick look at the website on my phone. It seems the CSS is not loading. It could be due to something trivial, like a http instead of a https before the URL of the CSS file or it could be something else altogether, it is difficult for me to find out more on a phone.
Thank you for taking the time to look
Keith
@calport + @kdmiller45 why not reach me asap? :slight_smile: I mean we can help client together.
Ok found the problem or atleast part of it, when I applied for the cert, I specified the domain and only put www.geekscove.com and left out the geekscove.com
fixed
