Show User Storage & Bandwidth without virtualmin web interface
Hi, How to showing storage and bandwidth user, without virtualmin web interface, Virtualmin API not available for make it
I also encounter the same issue when trying to download latest version, anyone can help? - Best Naperville Dentist
if you cant use the virtualmin api, for whatever reason, than you will either need to write your own subsystem to acheive this, or there is the webmin xml-rpc interface. this might be able to help you. might not. but it shouldent require any dependencies and you should be able to access it from any language, api, etc.
really depends alot on what your requirements are, and what your restrictions are. if you can provide more information on how you are going to need to implement this, and a little bit more information what tools you have availale to you… i might be able to come up with a better suggestion.
