I have been trying to figure out how to get example.com, example.net, example.info, and so forth to all resolve to the same directory on the virtualmin server. Can I do this? Thanks in advance for any help.
John
Yup, you can do that! All you’d need to do is make a Virtual Server Alias.
Once you select your domain from the dropdown list on the top-left of Virtualmin, go into Create Virtual Server, and select “Alias of YourDomain.tld”.
You can make as many aliases as you like for a given domain.
I had a feeling it was something easy that I was missing.
