I asked dyndns to know if it’s possible to create a name server with their free domain (like ns1.mywebsite.webhop.net) but they told me not because of an impossibility to make glue records.
It’s really nice an easier if i can do it like you said.
I will try all that this week and come back soon to tell you what’s happened.
But… Glue record changes takes much longer then normal dns updates, up to 24 hours compared to 1-8 hours for normal dns. The reason is because the root servers only update twice a day and I know a couple only do it once a day.
Finally, is it possible to use dyndns to point to my BIND or not?
Hmmm…I have no idea, though I imagine you could. But, why would you? The point of the DynDNS support in Virtualmin is so that DynDNS.org provides your DNS service.
As I said earlier, it is not possible to reliably run a name server on dynamic IP. So the simple solution is to not run a DNS server on a dynamic IP. Let DynDNS provide your DNS service, and let Virtualmin setup the IP synchronization so that DynDNS mostly knows where your server is.
I suspect we’re working against a language barrier (I’m pretty sure English is not PatTzZ’ native tongue), in addition to a bit of inexperience on the part of PatTzZ, rather than any intent to waste folks time.
Scott’s right that it’s generally considered good form to let people know when you’re discussing the same issue in multiple locations (and conversely, bad form to post the same question to multiple locations without letting everyone know). In this case, a lot of folks did spend a lot of time trying to help, and it’s likely that spending a little time digesting their answers (which were almost universally correct both here and at the DynDNS forums) would have saved everybody some time. Reading some documentation never hurts, either…there’s quite a lot of really good documentation about DNS in a lot of different places, just a Google search away. (And the Webmin wiki also has some great BIND coverage written by Jamie, me, and some other folks.)
Relax, Scott. We’re all just trying to make things work and learn something new. PatTzZ hasn’t committed any great crime, he’s just having trouble understanding how DNS works. We have a lot of folks who don’t grok DNS the first (or second, or third) time around. It seems to be one of those topics that’s just too boring to spend enough time studying for most folks. You and I are weird enough to have found it interesting, so we didn’t fall asleep when we read about how it works.
PatTzZ, you’re welcome to ask any question you have (dumb or otherwise). That’s what the forums are for. Scott’s not renowned for his patience. Knowledge, perhaps, but not so much patience.
I will say, however, that taking the time to actually understand DNS is probably the single best thing any web developer, system administrator, or even web designer, can do for their future productivity. The O’Reilly DNS and BIND book is the first one I recommend to anyone wanting to work with networked systems. The sections of the Webmin wiki on the topic are “light reading” in contrast, but will at least give you the basics.
actually the question is logical from a non english speaker point of view or per haps from a non specialist point of view.
because as the way of thinking goes ->ip needs to be static ->dyndns provides the correct route, so that must be converting non-static to static and if ns1.dyndns.org has an IP then why not use their IP for glue. hehe and that can not work as the IP’s keeps changing dynamically, that is why they are called Dyndns
If you try that service and check with a tool as intodns.com you will notice that everytime you call the domain, it has a set of IP’s that constantly change.
if your IP changes once a month or every three months you can use that to experiment with at home, but not for hosting purposes. If it changes more often then you will need to get a static IP from your provider, although likely this will be expensive.
I don’t think that terms like “wasting time” is appropriate at all. As a registered member one can ask questions and keep asking until the clouds in the head disappear.
As a member you can also choose not to answer and simply go on with your own business. There is no need ever to be rude.
And it IS ‘wasting’ my time and everyone elses when this user just can’t get his “yes” answer and needs to keep complaining about everyones answers. I take that as if they are calling me a idiot and they are the ones asking in 2 locations and getting the same flippin answers.
