Latest version virtualmin running on a ubuntu 16.04 AWS ec2 instance…
I click edit users > username > “Quota and Home Directory Settings”
and i only see Home Directory: Automatic / Subdirectory of Server’s home: _________
update: this seems to have something to do with xen AWS ubuntu ec2 instances. I tried virtualmin on ubuntu on a another web hosting company that uses kvm and I see that I can set quotas there, so something is definitely a little off the mark on this AWS server? I tried to “enable” disc quotas also in the webmin settings, and it gave an error:
Failed to turn on quotas : quotaon: using //aquota.user on /dev/xvda1 [/]: No such process quotaon: Quota format not supported in kernel.
That is strange, using KVM or Xen should have no influence on quotas. CentOS 7 is using xfs now but it also supports quotas and so does Ubuntu of course, assuming you are not using something like ZFS as storage…
