Is there any way to define a default site that will be viewed when the server is accessed via ip? Currently it goes to the first site it hits in the virtual server list.
Thanks.
Thanks.
Yup! If you select the domain you want as the default from the dropdown list on the top-left of Virtualmin, click Server Configuration -> Website Options, and select “Default website for IP address”.
Thanks for the heads up. It was so obvious that I completely overlooked it.
