Hi;
This problem has returned again, I am guessing that there’s a cron job running either on my VPS or on the host server that is breaking my system.
Disk Quotas is not enabled in Webmin, well I assume it is as the only option I have under that menu is " Enable Quotas". When I run the command to fix the problem, switching off quotas with quotaoff -a throws and error as below, but this might be because quotas is not enabled in webmin ?!
# quotaoff -a
quotaoff: Cannot find quota file on / [/dev/simfs] to turn quotas on/off.
# quotacheck -ugamn
I don’t really need quotas, so in Module Config, I have set “Quota setup for domain and mail users?” to no, but how do I completely disable quotas, and what might the recurring cause of this be ??
I have a suspicion that although quotas is disabled in webmin, virtualmin may assume that it’s enabled, and is trying to work without the necessary files etc, but I must admit I’m not really sure what’s going on.
P
Oh dear, something else is broken as well, none of the emails are making it to the mailboxes:
## Maillog
Jul 14 08:13:00 alpha postfix/local[19594]: A008F4099C57: to=<xxx@domain.com>, orig_to=<xxx@domain.com>, relay=local, delay=0.16, delays=0.13/0/0/0.02, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jul 14 08:15:20 alpha postfix/local[20407]: 5D68A4099C57: to=<xxx@domain.com>, orig_to=<xxx@domain.com>, relay=local, delay=0.17, delays=0.14/0/0/0.03, dsn=5.2.0, status=bounced (can't create user output file)
##procmail log
From home@peter-c.net Tue Jul 14 08:13:00 2009
Subject: 415
Folder: /home/xxx/homes/pac/Maildir/new/1247559180.19595_0.alph 658
Time:1247559180 From:xxx@xxx.net To:xxx@xxx.com User:pac.ivessusa Size:706 Dest:/home/ivessusa/homes/pac/Maildir/new/1247559180.19595_0.alpha Mode:None
procmail: Quota exceeded while writing "/home/ivessusa/homes/sue/Maildir/tmp/1247559320.20408_0.alpha"
procmail: Quota exceeded while writing "/home/ivessusa/homes/sue/Maildir/tmp/1247559320.20408_1.alpha"
Help !!!
