Hi guys,
I created a new Virtual Sub Server this morning however things have gotten a little mixed up.
what should default ownership of “/usr/local/” be?
(currently i have 2 options…either “root:root” or “root:staff”) -
Virtualmin automatically added a “gid” via “setgid” to /usr/local/.
Should i change the “setgid”?
Unchecking it on the permissions “setgid” check box does not work!
I also try to put a “0” in front of 755 (ie 0755)…this also does not work!
Does it matter if Virtualmin insists on having the “2” in front of 755 (ie “2755”)?
What “setgid” in ownership should /usr/local/ have by default?
is it a security risk currently “2755”
What Id does the “2” refer to compared with “0”?
What i have also noticed is that one of my subservers did have ioncube loaders showing up in info.php under Addon Modules. Since this cockup, that has now dissapeared!
