Set CustomField during "virtualmin create-domain" - Documentation need to be more clear!
I wonder how to set the value of a custom-field by using virtualmin create-domain via CLI.
I found that in the documentation there is a * behind this option …[--field-name value]* but I don’t see what it means.
First I thought it is a footnote, but there isn’t any at the page.
I have to custom fields at my Server: CustomerNo and CustomerEmail.
I tried to set it like this (without success):
virtualmin create-domain --domain a1atest.my.shop --virtualmin-nginx --virtualmin-nginx-ssl --dir --parent my.shop --field-name CustomerNo "xXx"
I just get:
Custom field name does not exist
At least I figured out, that it’s meant like this:
[--field-<yourFieldNameHere> value]*
Result in this working example:
virtualmin create-domain --domain a1atest.my.shop --virtualmin-nginx --virtualmin-nginx-ssl --dir --parent my.shop --field-CustomerNo "xXx"
Can somebody please add a footnote to the documentation, or optimize the way the parameter is described (even in the CLI with using “virtualmin --help”)?
Another small feature wish:
