I have to migrate one or two Plesk sites into Virtualmin Pro that use SSL.
In Plesk they have separate document roots for regular HTML content and for SSL content (“httpdocs” & “httpsdocs”). is there an option to do this in VM? (I thought I saw it once, but now I need to use it, I can’t find it!).
Yeah, Virtualmin will typically use the same DocumentRoot for both of those.
If you’d like to change that, you can look in Services -> Configure Website and Services -> Configure SSL Website – you can change the DocumentRoot for one of those.
