Security solution Imunify360, Bitninja etc
Is there any solution for Webmin/Virtualmin for security, like Imunify360, Bitninja, etc…
Is it possible to integrate it into Webmin?
Or please suggest a similar solution compatible with Webmin/Virtualmin.
I installed the Bitninja trial no problem, I would think Imunify360 would be the same. Bitninja portal handles everything, No need for any intergration if you mean configuring in webmin via a module.
