I would like to create a script that allows me to access the server 2 to server 1 take the backup made with virtualmin and restore the backup of a server on server 2 but I did not know if I can indicate the source via ssh I guess someone help?
virtualmin restore-domain --source ssh://root:password@192.168.1.1/HD_Ext/pippo.it.tar.gz --all-domains --all-features
In your opinion is right? The server has an ip 192.168.1.1 the server has 2 ip 192.168.1.2
Locutus
November 29, 2010, 8:14pm
2
Syntax looks okay, except for the fact that the keywords are denoted by two hyphens, like “--source
”, “--all-domains
” and “--all-features
sorry, had to copy and paste error.
The problem seems to connect the source ssh
Locutus
November 29, 2010, 9:22pm
4
Well, the syntax for the SSH looks okay. Can you elaborate? What exactly is the problem?
Missing or invalid restore file
Restores a Virtualmin backup, for the domains and features specified
on the command line.
virtualmin restore-domain --source file
[–test]
[–domain name] | [–all-domains]
[–feature name] | [–all-features]
[–except-feature name]
[–reuid | --no-reuid]
[–fix]
[–option feature name value]
[–all-virtualmin] | [–virtualmin config]
[–only-features]
[–shared-ip address | --ip address | --allocate-ip]
[–only-missing | --only-existing]
Multiple domains may be specified with multiple --domain parameters.
Features must be specified using their short names, like web and dns.
The source can be one of :
Locutus
November 29, 2010, 10:09pm
6
Okay, I suppose then the SSH connection/retrieval does not work… Wrong username, password, IP, path or filename maybe? Connection problem?
Locutus
November 29, 2010, 11:51pm
8
Okay, sorry, no idea here then. Good luck anyway!
