Where does Virtualmin store information about the install path and other details related to a script installed via the Script Installer?
I’ve recently manually moved a script into a new directory, however Virtualmin still thinks it’s in the old directory.
-Peter
I solved the problem myself, LoLz.
For anyone who’s wondering the answer to this riddling question, you can find the config file under the directory:
/etc/webmin/virtual-server/scriptlog/
Each config file is numeric, but you can do something like:
grep -r “old/path/to/script” /etc/webmin/virtual-server/scriptlog
Best Regards,
Peter Knowles
TPN Solutions
E: pknowles@tpnsolutions.com
P: 604-782-9342
W: http://www.tpnsolutions.com
