This is what the command "yum check-update" outputs:
[code:1]
Loaded plugins: fastestmirror, priorities
Loading mirror speeds from cached hostfile
- rpmforge: apt.sw.be
- base: ftp.hosteurope.de
- updates: ftp.hosteurope.de
- addons: ftp.hosteurope.de
- extras: ftp.hosteurope.de
virtualmin | 951 B 00:00
virtualmin-universal | 951 B 00:00
rpmforge | 1.1 kB 00:00
base | 1.1 kB 00:00
updates | 951 B 00:00
addons | 951 B 00:00
extras | 1.1 kB 00:00
468 packages excluded due to repository priority protections
audit-libs.i386 1.7.7-6.el5_3.3 updates
audit-libs.x86_64 1.7.7-6.el5_3.3 updates
audit-libs-python.x86_64 1.7.7-6.el5_3.3 updates
clamav-db.x86_64 0.95.1-4.el5.rf rpmforge
curl.x86_64 7.15.5-2.1.el5_3.4 updates
file.x86_64 4.17-15.el5_3.1 updates
filesystem.x86_64 2.4.0-2.el5.centos base
freetype.x86_64 2.2.1-21.el5_3 updates
libselinux.i386 1.33.4-5.1.el5 base
libselinux.x86_64 1.33.4-5.1.el5 base
libselinux-devel.x86_64 1.33.4-5.1.el5 base
libselinux-python.x86_64 1.33.4-5.1.el5 base
net-snmp.x86_64 1:5.3.2.2-5.el5_3.1 updates
net-snmp-libs.i386 1:5.3.2.2-5.el5_3.1 updates
net-snmp-libs.x86_64 1:5.3.2.2-5.el5_3.1 updates
perl-DBD-Pg.x86_64 1.49-2.el5_3.1 updates
php.x86_64 5.1.6-23.2.el5_3 updates
php-cli.x86_64 5.1.6-23.2.el5_3 updates
php-common.x86_64 5.1.6-23.2.el5_3 updates
php-gd.x86_64 5.1.6-23.2.el5_3 updates
php-imap.x86_64 5.1.6-23.2.el5_3 updates
php-mbstring.x86_64 5.1.6-23.2.el5_3 updates
php-mysql.x86_64 5.1.6-23.2.el5_3 updates
php-odbc.x86_64 5.1.6-23.2.el5_3 updates
php-pdo.x86_64 5.1.6-23.2.el5_3 updates
php-pgsql.x86_64 5.1.6-23.2.el5_3 updates
php-snmp.x86_64 5.1.6-23.2.el5_3 updates
php-xmlrpc.x86_64 5.1.6-23.2.el5_3 updates
policycoreutils.x86_64 1.33.12-14.2.el5 base
popt.x86_64 1.10.2.3-9.el5 base
rpm.x86_64 4.4.2.3-9.el5 base
rpm-libs.x86_64 4.4.2.3-9.el5 base
rpm-python.x86_64 4.4.2.3-9.el5 base
wbm-virtual-server.noarch 2:3.69-1 virtualmin-universal
wbm-virtualmin-awstats.noarch 2:4.1-1 virtualmin-universal
wbm-virtualmin-svn.noarch 2:4.3-1 virtualmin-universal
wbt-virtual-server-theme.noarch 2:7.1-1 virtualmin-universal
[/code:1]
Quite a lot more than I thought. I guess I’ll start next week looking to resolve those odd yum messages that prevent the update.
If you want to see them, here they are:
[code:1]
Setting up Update Process
Resolving Dependencies
–> Running transaction check
—> Package php-xmlrpc.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package policycoreutils.x86_64 0:1.33.12-14.2.el5 set to be updated
–> Processing Dependency: libselinux-utils for package: policycoreutils
—> Package php-odbc.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package wbm-virtual-server.noarch 2:3.69-1 set to be updated
—> Package wbt-virtual-server-theme.noarch 2:7.1-1 set to be updated
—> Package curl.x86_64 0:7.15.5-2.1.el5_3.4 set to be updated
—> Package audit-libs.x86_64 0:1.7.7-6.el5_3.3 set to be updated
–> Processing Dependency: clamav-server = 0.95.1-1.vm.el5 for package: clamav-server-sysv
—> Package net-snmp.x86_64 1:5.3.2.2-5.el5_3.1 set to be updated
—> Package libselinux-devel.x86_64 0:1.33.4-5.1.el5 set to be updated
—> Package libselinux.i386 0:1.33.4-5.1.el5 set to be updated
—> Package freetype.x86_64 0:2.2.1-21.el5_3 set to be updated
—> Package perl-DBD-mysql.x86_64 0:4.010-1.el5.rf set to be updated
—> Package popt.x86_64 0:1.10.2.3-9.el5 set to be updated
—> Package php.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package wbm-virtualmin-awstats.noarch 2:4.1-1 set to be updated
—> Package php-common.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package rpm-python.x86_64 0:4.4.2.3-9.el5 set to be updated
—> Package file.x86_64 0:4.17-15.el5_3.1 set to be updated
—> Package wbm-virtualmin-svn.noarch 2:4.3-1 set to be updated
—> Package php-snmp.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package rpm-libs.x86_64 0:4.4.2.3-9.el5 set to be updated
—> Package net-snmp-libs.i386 1:5.3.2.2-5.el5_3.1 set to be updated
—> Package libselinux.x86_64 0:1.33.4-5.1.el5 set to be updated
—> Package audit-libs.i386 0:1.7.7-6.el5_3.3 set to be updated
—> Package php-imap.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package php-cli.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package net-snmp-libs.x86_64 1:5.3.2.2-5.el5_3.1 set to be updated
–> Processing Dependency: data(clamav) for package: clamav
–> Processing Dependency: data(clamav) for package: clamav-lib
—> Package php-pdo.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package rpm.x86_64 0:4.4.2.3-9.el5 set to be updated
—> Package filesystem.x86_64 0:2.4.0-2.el5.centos set to be updated
—> Package audit-libs-python.x86_64 0:1.7.7-6.el5_3.3 set to be updated
—> Package clamd.x86_64 0:0.95.1-4.el5.rf set to be updated
–> Processing Dependency: clamav = 0.95.1-4.el5.rf for package: clamd
—> Package perl-DBD-Pg.x86_64 0:1.49-2.el5_3.1 set to be updated
—> Package php-pgsql.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package libselinux-python.x86_64 0:1.33.4-5.1.el5 set to be updated
—> Package php-gd.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package php-mbstring.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package php-mysql.x86_64 0:5.1.6-23.2.el5_3 set to be updated
—> Package clamav-db.x86_64 0:0.95.1-4.el5.rf set to be updated
—> Package clamav-data-empty.x86_64 0:0.95.1-1.vm.el5 set to be updated
—> Package libselinux-utils.x86_64 0:1.33.4-5.1.el5 set to be updated
–> Processing Dependency: /usr/bin/freshclam for package: virtualmin-base
–> Finished Dependency Resolution
virtualmin-base-1.0-61.rh.noarch from installed has depsolving problems
–> Missing Dependency: /usr/bin/freshclam is needed by package virtualmin-base-1.0-61.rh.noarch (installed)
clamav-server-sysv-0.95.1-1.vm.el5.x86_64 from installed has depsolving problems
–> Missing Dependency: clamav-server = 0.95.1-1.vm.el5 is needed by package clamav-server-sysv-0.95.1-1.vm.el5.x86_64 (installed)
clamd-0.95.1-4.el5.rf.x86_64 from rpmforge has depsolving problems
–> Missing Dependency: clamav = 0.95.1-4.el5.rf is needed by package clamd-0.95.1-4.el5.rf.x86_64 (rpmforge)
Error: Missing Dependency: /usr/bin/freshclam is needed by package virtualmin-base-1.0-61.rh.noarch (installed)
Error: Missing Dependency: clamav = 0.95.1-4.el5.rf is needed by package clamd-0.95.1-4.el5.rf.x86_64 (rpmforge)
Error: Missing Dependency: clamav-server = 0.95.1-1.vm.el5 is needed by package clamav-server-sysv-0.95.1-1.vm.el5.x86_64 (installed)
[/code:1]
