Running Install script I get a error
OS type and version Alma 9.4
Webmin version not installed yet
Virtualmin version not installed yet
Webserver version not installed yet
Just tried to install in Alma Linux 9.4 at Vultr and I see this error
the log shows
[root@server ~]# vi virtualmin-install.log
Last metadata expiration check: 0:05:37 ago on Sat 28 Sep 2024 10:18:40 AM UTC.
Package dnf-plugins-core-4.3.0-13.el9.noarch is already installed.
Dependencies resolved.
Nothing to do.
Complete!
Installing core plugins for package manager: Success.
Spin pid is: 5385
2024-09-28 10:24:19 URL:https://software.virtualmin.com/vm/7/rpm/virtualmin-gpl-release.noarch.rpm [18879/18879] → “virtualmin-gpl-release.noarch.rpm” [1]
Downloading Virtualmin 7 release package: Success.
Spin pid is: 5471
warning: virtualmin-gpl-release.noarch.rpm: Header V4 RSA/SHA256 Signature, key ID b9a0b8b7: NOKEY
error: can’t create transaction lock on /var/lib/rpm/.rpm.lock (Resource temporarily unavailable)
error: /etc/pki/rpm-gpg/RPM-GPG-KEY-webmin: key 1 import failed.
error: /etc/pki/rpm-gpg/RPM-GPG-KEY-virtualmin-7: key 1 import failed.
Checking for HTTP client … found /usr/bin/wget -nv
2024-09-28 10:23:58 URL:https://software.virtualmin.com/lib/slib.sh [24222/24222] → “slib.sh” [1]
[2024-09-28 10:23:58 UTC] [INFO] Log will be written to: /root/virtualmin-install.log
[2024-09-28 10:23:58 UTC] [DEBUG] LOG_ERRORS_FATAL=1
[2024-09-28 10:23:58 UTC] [DEBUG] LOG_LEVEL_STDOUT=INFO
[2024-09-28 10:23:58 UTC] [DEBUG] LOG_LEVEL_LOG=DEBUG
[2024-09-28 10:24:02 UTC] [INFO] Started installation log in /root/virtualmin-install.log
[2024-09-28 10:24:02 UTC] [DEBUG] Phase 1 of 4: Check
Spin pid is: 4861
Syncing system time …
… done
Checking system time: Success.
I just tried a Rocky 9.4, getting same error.
