Now installing redmine version 0.7.3 …
Failed to install script : Failed to open /home/foodomain.tld/public_html/redmine/public/stylesheets/redmine/mephisto.css for writing : Bad file descriptor
When this happend?
During installation?
Are you running some other rails applications on your server?
My script is derivated from other install script and I hope that I’ve followed API instructions.
File descriptor seems to be problem somewher else.
Please let me know if you will find something.
Hi!
This happens on install. There are no other rails applications on the server or domain.
Other install scripts work fine!
sub script_redmine_desc
return "redmine";
sub script_redmine_uses
return ( "ruby", "proxy" );
sub script_redmine_longdesc
return "Redmine is a flexible project management web application.";
sub script_redmine_versions
return ( "0.7.3" );
sub script_redmine_category
return "Project Management";
sub script_redmine_depends
local ($d, $ver) = @_;
local @rv;
&has_command("ruby") || push(@rv, "The ruby command is not installed");
&require_apache();
&has_proxy_balancer($d) ||
push(@rv, "The Apache proxy module is not installed");
&has_domain_databases($d, [ "mysql" ]) ||
push(@rv, "redmine requires either MySQL database");
return @rv;
sub script_redmine_params
local ($d, $ver, $upgrade) = @;
local $rv;
local $hdir = &public_html_dir($d, 1);
if ($upgrade) {
# Options are fixed when upgrading
local ($dbtype, $dbname) = split(//, $upgrade->{‘opts’}->{‘db’}, 2);
$rv .= &ui_table_row(“Database for redmine tables”, $dbname);
local $dir = $upgrade->{‘opts’}->{‘dir’};
$dir =~ s/^$d->{‘home’}///;
$rv .= &ui_table_row(“Install directory”, $dir);
else {
# Show editable install options
local @dbs = &domain_databases($d, [ “mysql” ]);
&ui_database_select(“db”, undef, @dbs, $d, “redmine”));
$rv .= &ui_table_row(“Install sub-directory under <tt>$hdir</tt>”,
&ui_opt_textbox(“dir”, “redmine”, 30,
“At top level”));
$rv .= &show_mongrels_ports_input($d);
return $rv;
sub script_redmine_parse
local ($d, $ver, $in, $upgrade) = @_;
if ($upgrade) {
# Options are always the same
return $upgrade->{‘opts’};
else {
local $hdir = &public_html_dir($d, 0);
$in->{‘dir_def’} || $in->{‘dir’} =~ /\S/ && $in->{‘dir’} !~ /../ ||
return “Missing or invalid installation directory”;
local $dir = $in->{‘dir_def’} ? $hdir : “$hdir/$in->{‘dir’}”;
local ($newdb) = ($in->{‘db’} =~ s/^*//);
local $mongrels = &parse_mongrels_ports_input($d, $in);
return $mongrels if (!int($mongrels));
return { ‘db’ => $in->{‘db’},
‘newdb’ => $newdb,
‘dir’ => $dir,
‘mongrels’ => $mongrels,
‘path’ => $in{‘dir_def’} ? “/” : “/$in{‘dir’}”,
sub script_redmine_check
local ($d, $ver, $opts, $upgrade) = @;
if (-r “$opts->{‘dir’}/config/database.yml”) {
return “Redmine appears to be already installed in the selected directory”;
local ($dbtype, $dbname) = split(//, $opts->{‘db’}, 2);
foreach my $t (@redmine_tables) {
local $clash = &find_database_table($dbtype, $dbname, $t);
$clash && return “redmine appears to be already using the selected database (table $clash)”;
$opts->{‘mongrels’} ||= 1;
return undef;
sub script_redmine_files
local ($d, $ver, $opts, $upgrade) = @_;
local @files = ( { ‘name’ => “source”,
‘file’ => “redmine-$ver.tar.gz”,
‘url’ => “http://rubyforge.org/frs/download.php/39477/redmine-$ver.tar.gz” } );
sub script_redmine_commands
return ("ruby", "gcc", "make");
sub script_redmine_install
local ($d, $version, $opts, $files, $upgrade) = @_;
local ($out, $ex);
&has_command("gem") || return (0, "The Ruby gem command is not installed");
if ($opts->{‘newdb’} && !$upgrade) {
local $err = &create_script_database($d, $opts->{‘db’});
return (0, “Database creation failed : $err”) if ($err);
local ($dbtype, $dbname) = split(/_/, $opts->{‘db’}, 2);
local $dbuser = &mysql_user($d);
local $dbpass = &mysql_pass($d);
local $dbhost = &get_database_host($dbtype);
local $dberr = &check_script_db_connection($dbtype, $dbname,
$dbuser, $dbpass);
return (0, “Database connection failed : $dberr”) if ($dberr);
local $err = &install_ruby_gem("mongrel", undef, 1);
if ($err) {
return (0, "Mongrel GEM install failed : <pre>$err</pre>");
if (!&find_rails_command("mongrel_rails")) {
return (0, "Mongrel appeared to install, but mongrel_rails command ".
"was not found");
$err = &install_ruby_gem("rails", undef, 1);
if ($err) {
return (0, "Rails on Rails install failed : <pre>$err</pre>");
$err = &install_ruby_gem("mysql", undef, 1);
if ($err) {
return (0, "Rails MySQL driver install failed : <pre>$err</pre>");
if ($upgrade) {
# Stop the running redmine server
&script_redmine_stop_server($d, $opts);
local $temp = &transname();
local $err = &extract_script_archive($files->{‘source’}, $temp, $d,
$opts->{‘dir’}, “redmine-$ver”);
$err && return (0, “Failed to extract source : $err”);
local $cfilebase = “$opts->{‘dir’}/config/database.example.yml”;
if (!$upgrade) {
# Find a free port
$opts->{‘port’} = &allocate_mongrel_port(undef, $opts->{‘mongrels’});
# Setup DB config
local $cfile = "$opts->{'dir'}/config/database.yml";
&open_tempfile(CFILE, ">$cfile");
&print_tempfile(CFILE, "production:\n".
" adapter: mysql\n".
" database: $dbname\n".
" username: $dbuser\n".
" password: $dbpass\n".
" host: $dbhost\n");
&print_tempfile(CFILE, "development:\n".
&close_tempfile(CFILE);
&set_ownership_permissions($d->{'uid'}, $d->{'ugid'}, undef, $cfile);
# Run the DB creation script
$out = &run_as_domain_user($d, "cd ".quotemeta($opts->{'dir'})." && ".
"rake db:migrate RAILS_ENV=production");
if ($?) {
return (-1, "Database creation failed : <pre>$out</pre>");
if ($opts->{‘path’} ne ‘/’) {
# In config file
local $efile = “$opts->{‘dir’}/config/environment.rb”;
local $lref = &read_file_lines($efile);
foreach my $l (@$lref) {
if ($l =~ /^#\sActionController::AbstractRequest.relative_url_root/) {
$l = “ActionController::AbstractRequest.relative_url_root = ‘$opts->{‘path’}’”;
&flush_file_lines($efile);
# In CSS file
local $cssfile = "$opts->{'dir'}/public/stylesheets/redmine/mephisto.css";
local $lref = &read_file_lines($cssfile);
local $path = $opts->{'path'};
$l =~ s/url\(\/images/url\(${path}\/images/g;
&flush_file_lines($cssfile);
# In liquid.layout
local $lqfile = "$opts->{'dir'}/themes/default/layouts/layout.liquid";
local $lref = &read_file_lines($lqfile);
$l =~ s/<a\s+href="\/">/<a href="$path">/;
$l =~ s/action="\/search"/action="$path\/search"/;
&flush_file_lines($lqfile);
local $logdir = “$opts->{‘dir’}/log”;
if (!-d $logdir) {
&make_dir($logdir, 0700);
&set_ownership_permissions($d->{‘uid’}, $d->{‘ugid’}, undef, $logdir);
local (@logs, @startcmds, @stopcmds);
local @ports = split(/\s+/, $opts->{‘port’});
local $err = &mongrel_rails_start_servers($d, $opts, “redmine”, @startcmds,
@stopcmds, @logs);
return (0, $err) if ($err);
$opts->{‘log’} = join(" ", @logs);
&setup_mongrel_proxy($d, $opts->{‘path’}, $opts->{‘port’},
$opts->{‘path’} eq ‘/’ ? undef : $opts->{‘path’});
if (!$upgrade) {
# Configure server to start at boot
&setup_mongrel_startup($d,
join("\n", @startcmds),
join("\n", @stopcmds),
$opts,
1, "redmine-".$ports[0], "Mephisto Wiki");
if (!$upgrade) {
# Deny regular web access to directory
&protect_rails_directory($d, $opts);
local $url = &script_path_url($d, $opts);
local $adminurl = $url.“login”;
local $rp = $opts->{‘dir’};
$rp =~ s/^$d->{‘home’}///;
return (1, "redmine installation complete. Go to <a target=_new href=’$adminurl’>$adminurl</a> to manage it.<br />
", “Under $rp using $dbtype database $dbname”, $url, “admin”, “admin”);
sub script_redmine_uninstall
local ($d, $version, $opts) = @_;
&delete_mongrel_startup($d, $opts, “mongrel_rails start”, $opts->{‘port’});
local $derr = &delete_script_install_directory($d, $opts);
return (0, $derr) if ($derr);
&delete_mongrel_proxy($d, $opts->{‘path’});
®ister_post_action(&restart_apache);
&require_mysql();
foreach $t (&mysql::list_tables($dbname)) {
if (&indexof($t, @redmine_tables) >= 0) {
&mysql::execute_sql_logged($dbname,
"drop table ".&mysql::quotestr($t));
if ($opts->{‘newdb’}) {
&delete_script_database($d, $opts->{‘db’});
return (1, "redmine directory and tables deleted.");
sub script_redmine_stop
local ($d, $sinfo) = @_;
&script_redmine_stop_server($d, $sinfo->{‘opts’});
&delete_mongrel_startup($d, $sinfo->{‘opts’},
“mongrel_rails start”, $sinfo->{‘opts’}->{‘port’});
sub script_redmine_latest
return ( "http://rubyforge.org/frs/?group_id=1850",
"redmine-([0-9\.]+).tar.gz" );
sub script_redmine_start_server
local ($d, $opts) = @_;
return &mongrel_rails_start_servers($d, $opts, "redmine");
sub script_redmine_status_server
return &mongrel_rails_status_servers($d, $opts);
sub script_redmine_stop_server
&mongrel_rails_stop_servers($d, $opts);
sub script_redmine_site
return ‘http://www.redmine.org/’;
1;
return "redmine";
return ( "0.7.3" );
local @rv;
&require_apache();
return @rv;
local $rv;
if ($upgrade) {
else {
“At top level”));
return $rv;
if ($upgrade) {
else {
‘newdb’ => $newdb,
‘dir’ => $dir,
return undef;
local ($out, $ex);
$dbuser, $dbpass);
if ($err) {
"was not found");
if ($err) {
if ($err) {
if ($upgrade) {
if (!$upgrade) {
# Find a free port
# Setup DB config
if ($?) {
# In config file
# In CSS file
# In liquid.layout
if (!-d $logdir) {
@stopcmds, @logs);
if (!$upgrade) {
$opts,
if (!$upgrade) {
&require_mysql();
1;
