Roundcube successfully installed but not found...
Hi I have VPS with:
Operating system CentOS Linux 6.7
Webmin version 1.782
Problem.
I’ve installed Roundcube for one of the virtualservers using menu ‘Install scripts’
Installation process was successful (see img) but when iam trying to open roundcube url it says ‘404 page not found’
https://www.dropbox.com/s/oldgsn0vv2272j8/01.png?dl=0
https://www.dropbox.com/s/00bsiz2bplvhy08/02.png?dl=0
Any help?
thx
A.
Anyone with a help?
Whatever path you install it into, you should then be able to access it at domain.tld/roundcube_path/.
If that’s not working – you’d want to make sure you can access other files within domain.tld. Also verify that you see attempts to access roundcube in the Apache access log for that domain.
