Hi! I’m unable to install roundcube using virtualmin script. The installation output is
Downloading http://prdownloads.sourceforge.net/sourceforge/roundcubemail/roundcubemail-0.8.2.tar.gz ..
Downloading http://downloads.sourceforge.net/project/roundcubemail/roundcubemail/0.8.2/roundcubemail-0.8.2.tar.gz ..
Downloading http://freefr.dl.sourceforge.net/project/roundcubemail/roundcubemail/0.8.2/roundcubemail-0.8.2.tar.gz (3.55 MB) ..
Received 1024 bytes (0 %)
Received 364 kB (10 %)
Received 728 kB (20 %)
Received 1.07 MB (30 %)
Received 1.42 MB (40 %)
Received 1.78 MB (50 %)
Received 2.13 MB (60 %)
Received 2.49 MB (70 %)
Received 2.84 MB (80 %)
Received 3.20 MB (90 %)
Received 3.55 MB (100 %)
.. download complete.
PHP module mysql is required ..
Module is not available even after installation!
Installed OS is Debian 6. The php5-mysql package is installed. Any idea to solve this?
Even if I remove the php5-mysql pacakge, the output is the following
Installing package php5-mysql ..
Installing package(s) with command apt-get -y --force-yes -f install php5-mysql ..
Reading package lists...
Building dependency tree...
Reading state information...
The following NEW packages will be installed:
php5-mysql
0 upgraded, 1 newly installed, 0 to remove and 242 not upgraded.
Need to get 0 B/80.8 kB of archives.
After this operation, 276 kB of additional disk space will be used.
Selecting previously deselected package php5-mysql.
(Reading database ... 56921 files and directories currently installed.)
Unpacking php5-mysql (from .../php5-mysql_5.4.4-7_amd64.deb) ...
Processing triggers for libapache2-mod-php5 ...
Reloading web server config: apache2[Fri Oct 12 12:31:03 2012] [warn] module php5_module is already loaded, skipping
[Fri Oct 12 12:31:03 2012] [warn] NameVirtualHost zzz:80 has no VirtualHosts
Setting up php5-mysql (5.4.4-7) ...
Reloading web server config: apache2[Fri Oct 12 12:31:04 2012] [warn] module php5_module is already loaded, skipping
[Fri Oct 12 12:31:04 2012] [warn] NameVirtualHost zzzz:80 has no VirtualHosts
.. install complete.
.. done
