I got this error when I tried to install roundcube.
Fatal Error!
Failed to install script : Missing or invalid-looking version number
Please what do i do?
Click “Edit Virtual Server”, then at the bottom of the screen under “Features enabled” make sure to enable MySQL/MariaDB.
Then run the installation again.
Check “System Settings > Features and Plugins”… If it’s not enabled there, then it’s not available to a Virtual Server.
Thank for your assistance.
I think it is not available. Is there a way i can fix it?
A default install of Virtualmin would install either MariaDB or MySQL depending on when the system was setup, and/or what distro you were using.
Send a screenshot of your “Features and Plugins” page.
Also, what distro are you running, and which Virtualmin/Webmin/Usermin versions are you using?
*** The latter information can be found on your “Dashboard” ***
Thanks a lot. I found a way.
I had to start it from System setting, then save from Feature and plugins
then install from Edit Virtual Servers.
Thank you.
