SYSTEM INFORMATION | |
OS type and version: | Ubuntu Linux 20.04.3 |
Webmin version: | 1.981 |
**Virtualmin version:**6.17-3 | |
Related products version: | Apache version 2.4.4 |
Creating a reverse proxy worked flawlessly whilst everything was http://
But then we’ve got into a catch 22. If we allow the target server to contact letsencrypt for a cert, the proxy must pass through to .well-known transparently. Which it does. But then, to get a letsencrypt for the proxy, you need to stop it forwarding trffic to .well-known. Easy - just add a couple of lines to the proxy conf thus:
ProxyPass /.well-known/acme-challenge/ !
ProxyPassReverse /.well-known/acme-challenge/ !
and you can generate a letsencrypt cert for the proxy. Now - come refresh time, you have to tinker with the conf again.
I thought I’d be smart and create a little script to do all this, calling it from cron. Then I found the command I was dreaming of (generate-letsencrypt-cert) doesn’t exist, although the documentation and the virtualmin list-commands both insist it does exist.
So - I’m stumped. I don’t really want to re-invent the wheel. Any suggestions?
