I’m trying to config for more than 2 days and can’t get it working.
I have 3 websites with his own Dedicated IPs.
The PTR record rDNS is oks on the provider.
When I do the tests, I’m getting SMTP greeting errors because the SMTP Banner send the hostname of the server instead of the domain IP.
SMTP banner All banner greetings comply with SMTP specified format.
199.199.199.10 | 220 server.mydomain.com ESMTP Postfix (Debian/GNU)
Here is the error, it sending the hostname of the server instead of send hostname for this ip.
SMTP greeting
199.199.199.10 | WARNING: The hostname in the SMTP greeting does not match the reverse DNS (PTR) record for your mail server. This probably won’t cause any harm, but may be a technical violation of RFC5321
On cPanel servers, it does automatic rule over the file:
/etc/mail_reverse_dns.
And the file contents shows like /etc/hosts
This file have
I’m getting now green status on smtp banner and smtp greetings.
But I don’t know how, because the smtp banner shows the dedicated IP of this domain but the reverse is of the main IP shared.
Anyway, when i got to mxtools or dnsstuff, it is getting gree (OKS) on all options.
I believe will keep this config then. If I’m getting green status, it shows working oks?
I also tried to add this line on master.cf (commented this first line and added the second line)
