Hi. First of all My subject says part 2 because is related to this other named: “Restore virtualmin backup with different file system” . It is the closest I got to what I want.
I have:
server A with some virtualmin servers in regular home (/home)
I want:
Migrate all servers from server A to server B. Server B has a new mount point for websites (in RAID-1) which is: /mnt/md0/home
What I would like to work
Make backups from server A and then restore on Server B easy.
MY SOFTWARE / HARDWARE SETTING
Virtualmin: 6.09.gpl GPL
Webmin version: 1.942
RAM: 16GB
OS: Ubuntu Linux 18.04.4
Kernel and CPU: Linux 4.15.0-72-generic on x86_64
What did it happen when trying to restore backup ?
MySQL tables does not get restored.
The restore process halts when trying to copy database tables. So to complete process I have to copy database tables from old server manually because the restore halts. -
virtualmin domain file has old paths.
Since the home folder is different, also I have to adjust some paths on the virtualmin domain file.
Domain folder: /etc/webmin/virtual-server/domains
Domain ID: in Virtual Server Summary
Then do:
$ vi /etc/webmin/virtual-server/domains/<Domain ID> to edit manually or $ sed -e 's/=\/home/=\/mnt\/md0\/home/' -i /etc/webmin/virtual-server/domains/<Domain ID> to auto-edit.
- Protected Directories also has some issues.
Since “AuthUserFile” on protected directories cannot be relative, it has to be modified to with the new mount point for each site.
If I do manually 1, 2 and 3 sites start working. However, it would be nice that the restore process do not halt and continue restoring features even if the new mounting is different.
I also tried it with the “ignore” flag checked but I got the same result.
It might be possible to do that kind of restore if there was some field to specify a new mounting point (in case it is different from /home) when restoring. I would be nice to have that NEW FEATURE on Virtualmin.
However, it can also work if I just create the site first in the new server, then move the old folder to the new mount point in server B and then copy the database files (dump them or just copy files from /var/lib/mysql/). But in that case, then what would be the purpose of Virtualmin backup-restore module.
Thanks in advance.
