it’s a vps:
root@ns1:~# mount
/dev/vda2 on / type xfs (rw,usrjquota=aquota.user,grpjquota=aquota.group)
proc on /proc type proc (rw,noexec,nosuid,nodev)
none on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
none on /dev type devtmpfs (rw,mode=0755)
none on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
none on /dev/shm type tmpfs (rw,nosuid,nodev)
none on /var/run type tmpfs (rw,nosuid,mode=0755)
none on /var/lock type tmpfs (rw,noexec,nosuid,nodev)
none on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
none on /var/lib/ureadahead/debugfs type debugfs (rw,relatime)
/dev/vda1 on /boot type ext3 (rw)
Ah, you’re using XFS. That may be the problem, but I’m not sure… I’ll do a little digging to see if Virtualmin can setup quotas on an XFS-based filesystem.
ok thanks… anyway, i could just transfer file via ftp and re-create virtual server, right? at the moment i’ve only 2 virtual servers… but i’d like to have not problem in future with backup…
But backup from the same system, should not be create problems, right?
