Last night I had a HD crash, and I lost all the data for about 50 domains.
I’d setup a daily full backup, to another CentOS 5.4 Virtualmin box. So on the other Virtualmin box I have all the gz files for each domain.
When I try to restore those files, some domains work, but most of them I get two errors:
Creating MySQL database joomla_97fmfrutalmaster …
… MySQL database failed! : SQL desc db failed : Can’t create/write to file ‘/tmp/#sql_32e8_0.MYI’ (Errcode: 13) at …/web-lib-funcs.pl line 1332.
Well, the first message you shared suggests that it’s not seeing any Mailman lists… did you have any setup?
The second message looks like it’s having trouble re-importing a database entry… but it appears to be saying it already exists. Do things by chance work for you?
