If I hide a panel, Recent Logins for example, from the Dashboard the tooltip says I can restore it from within the Authentic Theme’s config page. Is there a way, other than resetting the theme defaults, to restore the panel/accordion as the only reference in the config that I can see is as in this image:
Yes, it was me being a bit dim, I had to select the item in ‘hidden accordions’ to de-select it. That wasn’t clear to me when there was only one item but became apparent when I had multiple items to be re-enabled.
