When I click on RESTORE from the scheduled backup that does INCREMENTAL virtualmin tries to restore from “kvm1/29-08-2012-inc” and fails.
When I click on RESTORE from the scheduled backup that does FULL virtualmin tries to restore from “kvm1/29-08-2012-full” and fails. It seems obvious, given that the last full backup was on the 26th. But changing the path to “kvm1/26-08-2012-full” ALSO fails. (BTW, shouldnt it suggest restoring from the last full backup?)
The error message is “Restore failed : The specified source does not contain any domains, or is not a Virtualmin backup”.
I downloaded one of the mydomain.tar.gz files from “kvm1/29-08-2012-inc” and tested it, the file is fine. I even extracted a copy of a DB from it and manually restored it. It also worked fine.
The minimum permissions for a S3 virtualmin backups are as follows. It is not advised to leave a key with full permissions inside your virtualmin install.
I am having this kind of issue right now across all my servers. I had one server wiped due to HDD failure and was trying to restore backup from S3. It’s just not working. I tried the same on another server, same thing.
Permissions are setup correctly as provided in this post. Any help in diagnosing what’s happening would be appreciated.
