Virtualmin :
Fcgi & FCGI issues on Ubuntu / Debian
Issue 1:
When changing to FCGI or CGI, if php downloads,
go to conf file and comment phpadmin flag line
php_admin_value engine Off
change to
#php_admin_value engine Off
Issue 2:
When FCGI troubleshooting flops and only Apache handler can be used.
Then try php-fpm because it can run the program as user this way we can save time for changing ownership each time from user to Apache and vice versa.
when install php-fpm
you have start service. upto latest version of virtualmin only one running version of php-fpm can be used.
A proper fpm work require addition add proxy_fcgi module
After installing make sure to goto virtualmin and make it detect
virtualmin -> system configuration -> Re-check configuration
Issue 3:
After changing FCGI or CGI it goes back to Apache / FCGI and CGI does not function
Possible cause I,
if this happens after additional php version is installed.
then
check if lib Apache is changed
go to virtualmin -> system configuration -> Re-check configuration
Check if our php is being detected
if detected, what version of mod_php is used
If mod_php is lower and on back end we have enabled the higher or different version of mod_php disable the module and enable once detected by virtualmin.
Possible cause II,
If a error happens stating something like
Restore failed : No section found for mod_fcgid directives
Then try to check if CGI module is installed.
php(version)-cgi
IF this does not solve still shows directory missing error
That would be probably because the document root and directory command has been edited on back-end
Eg:
docroot should be public_html
but on conf it has git like location
public_html/xyz
make sure you change this using virtualmin website option settings,
in apache config
<Directory /home/user/public_html>
added lines in <Directory “/home/user/public_html”> section of apache config
AddType application/x-httpd-php .php
AddHandler fcgid-script .php7.2
FCGIWrapper /home/user/fcgi-bin/php7.2.fcgi .php7.2
“/home/user/public_html/”
Additionally,
Some issue can be solved by below methods
Rename fcgi-bin, cgi-bin & etc folders in /home/user/ directory.
