To All-
I am running Virtualmin Pro and have a question. I am trying to import a medium size MySQL Table over 2.6MB in size - (I am doing this task through Phpmyadmin), after 30 seconds exactly the task dumps into “Internal Server Error”. When I look at the logs, I see:
[warn] mod_fcgid: process 2858 graceful kill fail, sending SIGKILL
I suspect his is the cause since I keep trying and see the same error after I attempt the import. I have made edits to php.ini and changed the script timeout from 30 to 60, looked for another setting with a 30 and could not find one.
Excuse my ignorance but how do I fix this issue? Thanks!
